Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Spin cyle I am having a high pitched sound during the spin cyle. Also at first it was making the sound and not even spinning when should have been. How do I fix this?
  • 2,071 Answers
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Hope it may help you;
Regards,
VOTIT
Posted on Sep 24, 2008
Washer won't spin on spin cycle but spins during other cyles
Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
Feb 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
During clothes washer spin cyle makes a high pitch squeeling sound like letting air out of a balloon very slowly
Thanks for choosing FixYa and welcome. You need to check the motor drive and spin bearing. It may be the bearing. The drive motor controls the spinning, draining, and the agitation. Usually, when noise is associated with the spin cycle, it is either one. It is not an easy fix. Make sure to follow your manual. If not, you may want to call out a professional.
May 02, 2011 | Kenmore Washing Machines
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
High pitch sound during rinse and spin cycle
makes loud squeel at end of spin cycle
Dec 27, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
