Question about Haier HWD1000
Hwd 1000 drain
I just got the HWD1000 and i'm having a little trouble understanding the owners manual description on how to drain it. I just wanted to know if i was suppose to put the drain tube in a bucket or in the sink or? Would be a great help. Thanks
Its tube can be dropped into a sink. I dont recommend a bucket--while its not a high water consumer, it would need like a 5 gal bucket. I have my hose connected to a dishwasher drain (Y connector) on the kitchen sink (unit also fits in the hole left by the removed dishwasher).
Posted on Sep 25, 2008
Can I find an owners manual for my water heater? If not, can someone help me understand how to determine the temperature setting in degrees?
Easiest way to do this is to set the water heater in the mid range and wait for it to heat and settle down, then take the temperature of the water from the drain valve. See if it is too hot or cold. Raise or lower it a little at a time and wait for it to settle. Check it again.
Nov 07, 2014 | Rheem 22V50FN 50 Gallon Ultra Low Nox...
My Haier HWD 1000 won't plug in without popping the outlet. It's Not the outlet, everything else works fine in it. and the washer pops ANY outlet.
sound like a wiring problem that keeps tripping it out poss water in wiring or a loose wire somewere have it checked by someone
Oct 13, 2014 | Haier Washing Machines
I don't understand some of the fuse box icons for my 2001 ford focus
I suggest check the description and right location abour each fuse and fuse panel box location in your owners manual or ask and try to download from Ford Owners Manual ...
Hope this helps.
Sep 25, 2011 | 2001 Ford Focus
Hwd-c1000txveme-u error code 8
The only reference to 'E08' I have is that there is a problem 'water level exceeds protection value'. Water level detection may not be operating correctly and requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 24, 2011 | Haier HWD1000
My Haier HWD 1000 is brand new. First time use and water is pouring out of bottom as it tries to fill the drum. Please send help!!!!
There is a button and debris trap on the front bottom right of machine.
Little door says push. Open it and undo the large screw plug.
Remove debis if any. Screw the plug closed until it is very tight.
Check for leaks on next wash cycle.
(Also check intake hose connections at back of machine.)
Dec 01, 2010 | Haier HWD1000
Haier HWD1000 Logo
207 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
