Washing Machines Logo
Posted on Sep 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have maytag front loader washer (MAH5500BW) that I bought in 2000. Everything works great except the water temprature setting does not change from cold to warm/hot. If it is on hot, it will change to worm and cold but the reverse does not work. Do you think the unit needs to be replaced? Thanks Behzad [email protected]
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
  • Posted on Sep 21, 2008
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607721
Points
3590
Your best bet wil be to replace the unit,since it has started to malfunction before it grounds the washer.
goodluck and God bless
pls do appreciate by rating this solution
4helpful
Our neptune front-loader has become extremely loud during spin cycles, you almost need hearing protection, otherwise, it works great
Ball bearings have worn out. Replace as a set. Replace Water seals in the drum. Check the bearing shaft for any scrub marks. Check bearing housing. Fix new bearings now
Water won't pump into machine
turn your water off andcheck the screen in the water lines ...both ends...both hoses...Godd luck!
14helpful
2answers
Planning to purchase a pair of 3000 Series Maytag Washer & Dryer. Is this a wise choice.
These days, everyone offers front loading washers and dryers. The things to know about them, is that unlike the old style top loading washers (and even the very old type of front washers from 20+ years ago) is that they function much differently.
First off, remember that you should only use He (High Efficiency) detergent and that the amount you'll be using is much less as well, so you'll have to change your habit of pouring in too much, as it will cause you problems.
You'll also need to get used to the different noises, or lack of, when the washer is running. Except for the spin cycle, you'll hardly know its running. Now about the spin cycle, most front loading washers go into "turbo" mode and get going very fast, which is great since it leaves the clothes barely damp in most cases when you take them out.
Now for the not so good issues with front loading washers. You'll want to also change your wash day habits by doing starting your laundry washing with the cold water washing first and finishing with your whites or hot water washing as the last load you do. The reason for this is that front loaders tend to retain just a little bit of water in them when they're done, and by doing the hot water loads last, you give the washer the best opportunity to keep any odor forming bacteria the least chance to start with.
Another key thing that none of the front load washer makers tell you to do is, keep the door of the washer open slightly when you're done with your laundry, as the door gaskets will hold some water and that is part of where the moldy smells, that many people experience, comes from. We've found that by doing that little thing, along with an occaisional wiping out of the door bellows gasket, keeps our washer from having any nasty odors.
Some folks recommend using special tablets once a month (Whirl-out), but I have an adversion to doing a "load" without clothes and hot water, and an cleaning tablet - seems to me that kinda of defeats the whole "less energy-less cost" premise of efficient front loaders. So by leaving the door open, we've avoided all that and haven' had the odor problems at all.
OK, by now you're wondering when I'm going to give you something on the Maytags you wanted to know about! Almost any front loading washer will do a great job and provide you with a decent working life. I prefer the GE, Maytag, Whirlpool, Kenmore, etc., but really don't like the LG's. My reasoning is that the LG's seem to have more issues with torn door gaskets and error codes than the others. While the LG's look nice and most folks buy them because they're so darned pretty, they are a disappointment in where it really counts, in my opinion.
So buy any of the American made washer/dryer units mention and you'll be very pleased with them, and by the way, the Maytag 3000 series, do look pretty nice too!
Take time to read your manual with your new appliances and you'll be ahead of most folks and get the best performance out of them for years to come!
Hope you find this Very Helpful and best regards!
I have a neptune front loader and I have to pretreat every item before washing. My clothes do not come clean..I have contacted Maytag several times but no one has ever replied. Can you help The repairman...
Look up the model unit and compare it to the models appear on countless Google search pages. I had a set that bought new after the introduction and what became a PR nighmare for Maytag as they tried to ignore the problem. I was unaware of any problems since there was never a recall just at the very end when they offered to take the nice looking front loader in exchange for a new regular top loader. Mistake number 2. My washer started to get a bad smell and being single and doing maybe three loads a week. Then the washer drum started retaining water, not inside, but surrounding. The only way I discovered is while cleaning I turned the drum. Depending on who you asked, even some Maytag salesmen as well as the folks at the big home improvement stores and it was said to be the "oil" that lubercates the drum, water that was needed to turn the drum and a couple referenced this whole manufacturing defeact that could not be fixed. I decided I would stick with the oil or water concept becasue it made sense. One evening, I Googled. I was sick. It would only get worse and to contact Maytag, was a joke. Instead of waiting for the day to come, I listed the dryer for sale with the washer free. I disclosed everything and I could have sold a100 sets. The lady who bought the set for $650 was putting it to a flip/rehab project. I hope you are not the one who bought her property -- she wasn't planning to go into detail with the future buyer,
3answers
Very small space, limited choices
I would recommend whirlpool since they bought out maytag .They are a great for support and warranty:)
MAH5500BW Neptune - water temperature not following panel random
this sounds like a energy saving switch,I would check your inlet screens first. then we can go from there.
Front loader won't release water
Plug off the wall, open up the top to check hoses coming from the inlet side. If your hose here is okay, check your receiver trays. If all this is fine, you have to change your water valves at the inlet side of your machine; before that check the connections to the valves.
It would be good to check all connections, for vibrations are a common problem. The connections should be tight.
Pl rate if helped...............
Maytag Washer won't switch from rinse to spin
You have a bad lid switch. Before I retired Maytag had a lid switch kit that improved the switch that was originally in it. The problem would usually present itself if a person accidentally dropped the lid with a bang which would put the lid switch out of adjustment.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
