Question about KitchenAid KGRA806PSS Gas Kitchen Range
Drawer beneath oven keeps falling off it's little wheels
I have a black kithen Aid superba gas range and ever since we got it the drawer which is very heavy kept falling to the ground off it's hinges or whatever the drawer hangs on. When we first got it I called the company we bought it from a few times and they said someone would get back to me and no one ever did. We have just lived with it and my husband would constantly remove it and try and figure out why it would stay on the track. Well now I have fianlly had it. Two days ago I went to pull out the drawer and it fell on my toes breaking my big toe. Of coarse there it nothing you can do about a broken toe, you just have to let it heal and try not to bear any weight on it, which ishard to do with a family and a job as a teacher. I am making a mjor complaint and I want the drawer fixed imnmediately. Has anyone else had this problem?
  • 706 Answers
I sympathise with your problem and sorry about your broken toe.. The drawer sits in a slide and the rollers on the drawer travel inside the track.. If your husband is reasonable handy ( or you ) ..empty the drawer and try to get the wheels into the track on the oven.. this process is similar to that used on some kuchen cabinet drawers and furniture so it is no different..just hard to see or get it started..
With the drawer out of the oven..use a flashlight and examine the track to make sure it is not damaged ( do the same thing on the mating slide/rollers of the drawer)..
If possible, can you return to the place you bought it from and have them show you how to do it? They owe you at least that much... Good luck and take care of that toe...
Posted on Sep 21, 2008
Smell of gas and excessive flame when using Superba
First thing to check is whether the stove is for LP or natural gas. Takes a different orifice size on each type of gas.
Nov 15, 2017 | Kitchen Ranges
I bought gas cook stove used. I have propane gas & I don't know what kind of gas the stove was set up for. When oven is on it smells strongly of gas, food cooked in oven has black soot on it and flame...
There is a regulator behind the bottom drawer remove the drawer.look in the back you will see a silver box that the oven fuel rail is on just below the rail there is a brass fitting that needs to be turned clockwise till it stops it can be hard to turn some times but turn it till there is no clearance between the nut part of the valve and the silver box then you can start your oven and it should work fine you can also adjust it to get a little more flame if needed.
Feb 03, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen aid superba oven is getting a error code of: F3-E0 the temperature won't go over 250
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 29, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Dual fuel kithen aid F 02
Welded element relay on the control board.
Brian
Apr 18, 2008 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Maytag Oven model MES5752BAW when using the bottom drawer it works hard to close and goes off track and one side is higher than the other. Please help on how to fix this problem this oven was bought Aug....
remove drawer entirely. and one side at a time try reinstalling the rear wheel over he fixed (mounted wheel on unit. one side at atime with drawer empty, always easier.its gonna take some fiddling but it'll go. if it falls off track regularly then its possible that the lower frame of unit has bent and might need a little "persuasion" to line up correctly
Mar 08, 2008 | Kitchen Ranges
Looking for a part KitchenAid DBL Convetion oven (12 years old)
Are you talking about the oven pan at the bottom of the oven? If so, the part number may be 1059318 and costs about $50. You can find parts for your range at repairclinic.com. Just type in your model number in the search window. There is an extensive pictorial part index with price infomration. Unfortunately, this part did not have a photo with it.
Feb 04, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
1,156 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
