Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung HLN617W Changing the lamp
Have no manual. Any directions?
Go to samsung .com they show you how
Posted on Sep 30, 2008
SAMSUNG HLN617W which comes on for 20 minutes then gets three blinking lights
You have found the fault! Clear the exhaust filter as there is not enough air cooling the lamp housing.
Mar 04, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Flickering
although the digital board could be a suspect, i would lean more to the dmd board. the board will hve to be repaired by a proper tv technician or it will lead to more critical state.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Jun 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
I have a Samsung HLN617w that has an awful buzzing noise that seems to be continuous and maybe from the lamp fan. Any suggestions on a fix?
This tv have a colors wheel is dying and worn out.The sound u hear buzzing,squiling or lound motor noises.The colors wheel require changing,because it dying and spinning off of it motor axis.Hire a tv Tech. to change the colors wheel,because it sit way inside near the Light Projection Engine it self,require take out many machanical parts even can come to the colors wheel itself to change it.
Nov 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Does it matter if bulb #bp96-00224ep is 100 watts or 120 watts?
Lamp for Model# HLN617W is BP96-00224B or BP96-00224J 120 watts Look on Ebay < I got my Lamp for $85.00
Mats 1-800-628-1118 for lamps
Nov 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w non power up
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
Mar 03, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Training Manual for HLN617W1X/XAA
Try Googling (Samsung)(HLN617W1X/XAA)(manual) without parens. For a service manual, you may have to contact Samsung directly.
Nov 07, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Hello
Problems with the lamp door detector switch. Try jumping out this switch and running it for a while. The switch is the small switch with the blue rocker arm activated by the tab on the lamp door panel.
Jan 31, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
