Question about Freezers
Won't get cold enough
Temp alarm is on and won't go away. it blows cool air but not cold air. won't get to zero degrees
  • 750 Answers
Welcome mvernon6
How old is your Freezer ?
Make and Model
This can be anyone of a host of problems,
1. Thermostat bad
2.Freon coolant low
3. Coolant leak.
4.Are the coils on the bottom of the freezer behind the grille or in the rear of the box?
These are the narrow black tubes that run parallel to each other, back and forth.
They carry the coolant to and from the compressor!
If they are under the freezer, then they may be covered with years of dust and lint and in need of a refrigerator brush down there to gently clean the stuff out!
Air needs to pass over them as the fan sucks it in through the front grille to cool them off.
The brush is $8-$10 at the hard ware store.
I hope my suggestions help.
Let me know how it goes.
Bless You Huuum
Please do not forget to leave a rating.
Below is an article I read about these things
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 22, 2008
We have a Frigidaire Model FFC25C8CWO 25cf commercial freezer chest. The alarm keeps going off. The temp is below zero and we can't get it to get warmer. What can I do? Is it to cold is this why the
Hello Judy, thanks for your post!
From my understanding the alarm on your Frigidaire commercial chest freezer continues to go off. You have explained that the temperature is at zero degrees. It sounds like you could have a potential issue with your thermostat or sensor. I would recommend having a professional technician come out to properly diagnosis your freezer to avoid any unnecessary part purchases. Good luck. -Matt
Dec 14, 2014 | Frigidaire Freezers
Cannot get temperature down
If the evaporator coils are not being insulated by ice formation then maybe the thermostat is defective not allowing the refrigerator to cycle for enough time to adequately cool. And if the unit is constantly running and cools insufficiently you might have developed a refrigerant leak.
Your internal freezer temp should be around zero to 4 degrees if all systems are go and you have good gaskets.
Mar 14, 2014 | Freezers
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Freezer temperature does not get below 10 degrees
this is something you can do now. Check this 1st:
make sure that the air vents are not blocked and that you didnt overload the freezer with food
there can be other things that will not bring the temp. below 10 (that temp. is not too bad as long as it doesnt spoil the food)
here are the possiblities:
t'stat is set too low
t'stat is not responding to zero degrees (all that means is it is shuting off the compressor too soon to reach zero)
dirty condenser
r-134a freon is a tad low (only takes like 9 oz. if lose 1 or 2 that is enough to affect performance)
the freon is the last thing to check cuase you have to call someone to do that for you...
Well hope this was helpful... check the temp often watch to see if it gets above 20 degrees cause that will spoil you food..
Mar 11, 2010 | Freezers
Amana BR18 fridge/freezer. Fridge is cool but not cold, freezer is at about 20 degrees. Ice cubes are frozen but ice cream is soft. Any ideas?
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
Oct 04, 2009 | Freezers
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
sounds like a sealed system problem lack of freon, possible tubing leak
May 03, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
285 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
