Question about Kenmore 24032\24036 Top Load Washer
Electric washing machine
Why are humps and notches of a timer cam plate sharply pointed
  • 550 Answers
To make sure of the time that the device will switch on/off or cycle
in use the armature rotates approximately 1 rev/hour, slowed down by a multi stage gearbox, & multiplied in force by the same factor
the switches are 1/2 ounce pressure,
there is no difficulty with timer motor being able to move the switches
do not file them 'smooth' it causes difficulty with program shifts
(have done it, once, only once, never again)
Posted on Oct 08, 2008
99 plimouth vollager timing position marks
On the 2.4liter four cylinder the marks on the camshafts are between the two cam sprockets. The left (exhaust) cam mark is the notch directly to the right of the UP mark and for the right (intake) cam the notch is directly to the left of the 2.4 FRONT mark. Line those two mark up with each other. The crankshaft mark is located on the sprocket. It is a triangle pointing upwards. You align that mark with the downward facing triangle located on the engine plate directly behind the crankshaft gear.
Nov 23, 2014 | Cars & Trucks
How do I align my Dial to my GE Washing Machine Timer
Most GE knobs and dials have either a flat spot or notch on the knob that aligns with a similar spot on the shaft. They can only go on one way.
Oct 20, 2014 | General Electric WH11X10033 Dial Assembly
Series 60 washer = Fill does not turn off.
Washing machines use timers to set fill and empty cycles. These have micro-switches that contact cams turned by the timer motor. Cams are circular metal discs with high points and low points. Something is probably misaligned. You usually can manually turn the timer control. If you turn it directly to the empty cycle and the fill valve opens, then the micro-switch controlling the fill valve is not contacting' the cam. It may just require bending the bracket holding the micro-switc.h so that it will contact the cam
Oct 04, 2013 | Kenmore Washing Machines
Need help putting back together
That plastic wheel has humps on it. The small copper winding is a motor that turns that wheel. As them humps on the wheel travel around slowly they open or close those points which power up the water valves motor and such. This type timer is not serviceable and cannot be repaired. You must purchase another.
Apr 12, 2013 | Washing Machines
Washing machine filled with water, started agitating, then stopped. smells electrical.
Washing machines are built, sealed so that water or any other liquid that enters into the drums, dryer compartments will be isolated and not penetrate to the electrical system of the unit. There are protections to the motors installed beneath. To give you an idea, a motor mostly installed on it is a split-capacitor single phase motor which is protected by a fuse, thermal overload sensor to prevent burning the winding. A possibilty of electrical burning smells is that, a possibility that the thermal protection of the motor winding didn't open or activate. So that the winding may have been burnt and i'm sure your machine will stop immediately. There is also that timers which are cam driven, there is a strip on the timers and switching between clockwise and counterclockwise rotationion is done here. There is also a possibility that this switches strip may have been warp and burning would have occured due to uneven contact points already, carbonization inside this switches would take place, and your machine would stop. I hope this will help, thanks
Feb 17, 2010 | Kenmore Washing Machines
I believe the timer on Whirlpool washer is bad. How do I test this using a voltmeter?
A timer consists of vertical cams (disks with pieces missing that sit on a horizontal shaft, the shaft is powered by a very slow geared down AC electric motor as the motor turns; lever switches above and, below the cams ride upon the cams opening and closing to program the machine to fill, agitate etc. the length of the cutout in the irregular disk (cam) is the lengh of time a certain procedure or,device i.e. a spin cycle, or, solenoid takes or, is activated and, it's corresponding switch is closed. All machines come with a small packet usually mounted inside the control center that has a frequency and, duration chart for the timer. this will show you the conectors on the timer that should be closed at a certain time in the cycle you can then manually turn the timer to the spot wher the meter should read continuity The most offen encountered problems with timers are burned switch contacts and, dead timer motors.
Apr 24, 2009 | Washing Machines
Dryer turns and timer works - just no heat ? What is the problem?
If it's a gas dryer, check the thermal fuse in the rear in unit,, a lead on each end,,white plastic with a hump on it,,,careful it's live if unit is plugged in
Apr 20, 2009 | Maytag Performa PAV2200
Replaced the coupler between the motor and transmission,
its a steel plate in the shape of a triangle each point has a notch which should line up with each posts of the base asm have someone help you by pulling the tub asm straight up to take the weight off so it will be easier to repostion suspension plate be careful of sharp edges
Dec 13, 2008 | Roper RAS8445KQ Top Load Washer
Washer stops and make clicking sound
sounds like the timer needs a little assistance to get "over the hump". perhaps many cam switches must be switched at his point of cam rotation. if machine is getting old, then attempt to lubricate the electric motor that turns the timer mechanism. also lube the shaft bushings for the timer cam plate as well if possible.
Aug 17, 2007 | GE WHRE5260E Top Load Washer
Machine not starting at all.
the white box you refer to contains the main module which drives the whole issue. with no start, this module is probably faulty and is an expensive part
Jun 17, 2007 | Hotpoint BWM20 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
