Question about Sony SLV-D950 DVD Player/VCR
SLV-D950G/I DVD Player / VCR Combo
Unit shows "------" where time is usually displayed. Also can hear a wiring sound inside machine. Not sure if it's worth fixing but would like to keep teh unit to play videos as thinking about buying a dvd recorder. Any clues what it might be
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
SOURCE: codes
06, 19 are the listed codes in the book
Posted on Feb 18, 2008
SOURCE: Code for universal remote control for Sony VCR/DVD Player SLV-D360P
I have a code that worked to program by comcast remote to this unit 20864
Posted on May 14, 2008
SOURCE: Sony SLV-D370P DVD Player / VCR Combo
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Posted on Sep 12, 2009
SLV-D350P DVD Player / VCR Combo remote codes
You may have to use a universal remote control.
Dec 21, 2017 | Sony SLV-D350P DVD Player/VCR
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
While trying to convert a VHS to a DVD, both are placed into the converter and I press the button indicating the process to begin conversion from the VHS tape to the DVD, but when I press the...
The Sony SLV-D300P is a DVD PLAYER and VCR. It does not record DVDs. You would have to buy a combo unit with a DVD recorder, not just a DVD player.
Mar 14, 2011 | Sony SLV-D300P DVD Player/VCR
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
Jan 23, 2011 | Sony SLV-D300P DVD Player/VCR
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
DVD freezes when playing on a Sony SLV D300P DVD/VCR
That particular unit is very sensitive to scratched or dirty disks. Remove the disk and make sure there are no finger prints, peanut butter & jelly, or popcorn butter stains on the back side. If there is, gently wash the disk under warm water with a DROP of mild dish detergent, being careful not to scratch the surface. Rinse the disk well and dry with a soft, lint free cloth (like an old cotton t-shirt) again being careful to avoid scratching the disk. Replace the disk and play.
If the disk is scratched, there is little hope of fixing the scratch so the unit can read it.....
Nov 20, 2009 | Sony SLV-D350P DVD Player/VCR
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D950 DVD Player/VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
