On my laptop, I cant connect with wireless connection.
  • 781 Answers
1. were you ever able to do it before?
2. first.. check your wireless adapter is on and you have a light showing you adapter is on (blue or green).. on some compaq laptops if you get an amber light and the switch is on the on position the wireless adapter may be faulty and your motherboard may have to be replaced.
3. check also you are within range of your access point (router).. usually on the system tray (where you clock is ) you will see icons showing you are within range or not (ex. a computer flasing a little blue light with some waves to right).
4. find if your computer detects your wireless adapter (go into start>right click my computer>properties>hardware tab> device manager... and look under network adapters! if you see your wireless adapter make sure you don't have a ? or a ! sign next to it.. if you do you may need to update the driver or reinstall the driver of this device. check the cd that came with the adapter or using another computer download the setup file/driver from the hardware manufacturer of your device and using a flash drive move it to the system you're working on and install the appropiate driver for your operating system.
Posted on Sep 21, 2008
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
My laptop cant browse when using wifi(chrome, firefox explore)I get the cant resolve host error. I am able to connect to the wireless router. I am able to browse if connected using ethernet. other wireless...
You are probably right. Your laptop is not playing well with others.
First check to see if your wireless adapter on your laptop is turned on.
Then click the icon that controls the wireless connections to see if you can see your network. If you can, click on the network name and see if you can log on.
Next, temporarily turn off any internet security programs you have to see if you are experiencing a firewall issue. Check to see if Windows firewall is turned on for the wireless connection. If so, turn it off until you connect.
Aug 03, 2010 | Computers & Internet
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
Wireless Connection
1. go to Start->control panel->network connections->wireless connection. 2. There you will find an option of repairing the wireless connection. select it and repair your connection.
Aug 30, 2009 | Acer Aspire 4315 Notebook
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless connection
it would be in network connections folder.Highlight the wireless connection in the right pane then in the left pane click on repair
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
