Question about Gefen ex-tend-it The VGA to ADC Conversion Box (VGA-2-ADc) Scan Convertor
Add a 22" Apple Cinema Display to an Ibook G4
I'm trying du add a 22" cinema display to my Ibook G4 Mac Os 10.4.2 with Gefen ex-tend-it The VGA to ADC and the Apple monitor is still black. Can you help me?
Vittorio  from GENEVA, SWITZERLAND
vizzo@iprolink.ch
    Genius:
  • 1,550 Answers
Your DVI port may be bad . You need to check it so take to near by Apple store to get it checked .
If it is under warranty replace the unit there is also chance that you might have got defective unit.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 21, 2008
  • 6,487 Answers
Make sure first that the monitor is detected, if its not detected try first to unplug/replug the connection . But if the monitor is detected but the screen is black that is a synch problem and there's some issue on this type of setup it will be better for you to contact Gefen ex-tend-it support..
Hope thet halps.........
    Genius:
  • 1,847 Answers
Use the video toggle key to transfer the picture to the cinema screen..
  • Legin Varghese
    Legin Varghese Sep 21, 2008
    This is usually the F7 or F8 key, and it should say CRT/LCD or have a
    small image of a monitor screen. Press both keys together, generally
    once but up to four times. This combination of keys toggles the display
    to show on the laptop only, the cinema screen only, or on the laptop and
    cinema screen at the same time.
  • Legin Varghese
    you may need to go into System Preferences>Displays and tell the computer to Mirror the screen and the LCD
I have a M8149 Cinema dispaly 22" and want to connect to late 2009 Mac mini. The monitor came with a strange adaptor set of ADC input to 1x each of usb, 24Pin 92x rows of 8) male ADC, and another plug...
The Apple 22" Cinema display M8149 (ADC) is one that is not compatible.
It might be better to find another brand display to work with your 2009 Mac Mini. The Apple model A1081 is DVI, but for the age (its 8 years old, the lamps are likely dimmer than new...) I would look for a resolution-compatible DVI input display (Dell Ultrasharp, etc..).
Jul 22, 2017 | Apple Computers & Internet
How to connect my ibook g4 mid 2005 to an lcd monitor
http://support.apple.com/kb/SP43
From the specs page "Video mirroring supports VGA video out to an external display or projector (requires included Apple VGA Video Adapter) and S-video and composite video out to a TV or VCR (requires optional Apple Video Adapter, sold separately)."
-=/ Daft Tech /=-
Oct 22, 2009 | Apple iBook G4 Mac Notebook
Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
Aug 03, 2009 | Apple Cinema Display Flat Panel Monitor...
22" Apple Cinema Display doesn't power on
This may be an issue with the display detecting the wrong video format or is using an unsupported resolution for this Apple Cinema Display 22"
Procedure:
• Make sure your Mac is turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Mac to start up.
If that does not help here is additional support reference from Apple regarding its LCD displays:
Apple Support Link:
Power Light Flash Issues
Let me know if this helps!
Regards,
-Mactechtrainer
Jul 02, 2009 | Apple 22" Cinema Display Monitor
My sreen powers of my desktop
Check your pins at the connector.  I had a problem like that before and it was a student who unplugged the cable and tried to reconnect but bent 2 pins which shorted out the computer and monitor.  If that isn't noticable try connecting the monitor to another computer or laptop and if it still does the shorting issue then its in the monitor cable or board on the monitor.
Apr 28, 2009 | Apple Power Mac G4 Desktop
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Gefen ex-tend-it The VGA to ADC Conversion Box (VGA-2-ADc) Scan Convertor Logo
341 people viewed this question
Top Gefen Televison & Video Experts
Are you a Gefen Televison and Video Expert? Answer questions, earn points and help others
