Question about Fuji Optics
Fujinon stabiscope 10 X 40 5degrees, S1040 leaver to cage and uncage has no spring tension
Hi. I have a 98 ST2 and just replaced the standard clutch springs with aftermarket. Tensioned them to 5 lb ft and the clutch won't go into gear. Just spins as if it still in neutral.
Is the clutch working correctly are the plates compressed. Without operating the clutch lever the clutch should be fully lock the center hub to the outside cage. Does the clutch front plate move when you squeeze the lever? If not I would suggest the springs are: - a) too long, b) not correct for your model or c) have too much tension in them and so holding the clutch open. I know they cost more but I would get OEM springs.
Hope this helps
Apr 07, 2014 | Ducati Motorcycles
How to disarm Fujinon SRD-92B Zoom Rate Demand
Remove end plate. Remove rate control knob and pot. Loosen up three set screws on housing, center zoom control, and slide entire assembly out the end of the housing. Where will you find a replacement spring?
Feb 28, 2013 | Fujinon Inc SRD-92B Zoom Rate Demand with...
Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Jan 09, 2012 | HP Photosmart C3180 All-In-One InkJet...
Gilera dna 50cc
check fluid level ,if low top up and try bleeding the pipe to expel air,
Mar 14, 2009 | 2002 Gilera Coguar
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Fujino Stabiscope S1240d/N
I don't know about the night vision bits but if it is the same as S-1240 then the 3-pin plug is a power input.
Regards,
Tony
Feb 01, 2008 | Fujinon Stabiscope S-1240 Binocular
Stableizer not working
Baker Marine in CA will fix your Stabiscope. They told me $1500 minimum for the same problem. They are the only ones in the Western World that fix these things, truly. I know of a guy in Denmark who was told to send his to Baker. They have no competition nor any canscience!!
Aug 07, 2007 | Fuji Stabiscope (7512404)
Optics Logo
241 people viewed this question
Top Fuji Optics Experts
Marvin
Marvin
Geoff White
Geoff White
Are you a Fuji Optic Expert? Answer questions, earn points and help others
