Question about Spotlight Garden
A motor trend 5,000,000 candle power halogen spotlight
I do not have the manual or instructions to make this product work. I am confused about how the battery goes
Replacement instructions
Good day, this is John the Hayward tech. I have given you a link to the Power Flo II owners guide. You will need to remove the screws on the front of the black plastic housing to access the impeller. Holding the shaft of the motor you will need to turn the impeller CC to remove. Once removed you will need to remove the four motor through bolts that both hold the motor together and hold the housing to the motor. Take a look at the manual parts breakdown. Strongly recommend letting a dealer perform this procedure. Always replace all gasgets and seals. http://www.hayward-pool.com/pdf/manuals/PowerFloLXandPowerFloII.pdf
Aug 27, 2014 | Hayward 1.0 HP Power-Flo II High...
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
I just bought the Pondmaster 260 pump from Overstock. There are NO instructions in the kit. Do you have a manual I could download on line? Thank you. Ellen Goodell
The manual is located on the Pondmaster site in PDF format: http://www.pondmaster.com/instructionsheets/ZG098.PDF
If you need the program to view it the reader is free at: http://www.adobe.com/products/acrobat.html
May 12, 2011 | Pondmaster PM 250 gph Mag Pump Pump 250...
Is there an instruction manual for these cleaners out there?
Here is a copy of the users manual for these pool cleaners:
http://www.zodiacpoolsystems.com/Product-Archive/Cleaners/~/media/Zodiac/Global/Downloads/H05551.ashx
Sep 12, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
I have a Montpelier floor standing fountain and it eats halogen bulbs. It's supposed to take 12v bulbs but I measure the voltage output from the AC adapter and it's putting out 25 volts. What's up?
Your ac adapter is bad or the supply voltage to the adapter has changed for some reason.
Try plugging the adapter in some where else and verify the voltage. If this does'nt work buy another adapter that will give you the 12volts you are needing. Remember do not touch the halogen bulbs with your bare fingers because this will ruin the bulb.
John
Sep 28, 2009 | Hunter Kenroy 50151cop Kenroy Montpelier...
E-100
Hayward has all their owners manuals on the web at
http://www.haywardnet.com/aboveground/products/manuals.cfm#FiltersSand
if your model is older and not on the current list, you will find a model with the same top valves are yours as they haev made very little changes over the years.
Mar 01, 2009 | Garden
3-light LED spotlight kit with remote solar panel #555-208
The Spotlight kit should still be under warranty for at least a year through the manufacturer. Check your manual and contact the manufacturer. The problem might be the seal which is allowing water in and therefore it needs to be replaced
Sep 10, 2008 | Spotlight Aquascape Water Proof LED 2-Watt...
Garden Logo
429 people viewed this question
Top Spotlight Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
Are you a Spotlight Garden Expert? Answer questions, earn points and help others
