Question about Canon SmartBase MP360 All-In-One InkJet Printer
Error code printer check ** 343
Got this on canon smartbase mp360
  • 1 more comment
  • marshlandfar Sep 21, 2008
    cant get it into service mode-any ideas
    tried pressing menu copy copy copy scan but wont go in service mode.what can i do
  • marshlandfar Sep 22, 2008
    absolutely fantastic advice.worked well.cant thank you enough.you have saved me a small fortune on repairs as canon wanted to charge me £90.00 to even look at it
  • 1,031 Answers
The error is "Waste Ink Tank Full" error
This error occurs after a set number of nozzle activations, and it's to protect you from having ink start leaking out of your printer.
The waste ink tank is actually a large cotton pad in the bottom of the machine which absorbs the waste ink, and if this pad becomes full, the ink will pool and, like water, seek the path of least resistance, which could be where the case parts connect, and then leaking out onto your desk or carpet...
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
hope it works for your model
Hope it helps.
goodluck pls dont forget to rate this
Posted on Sep 21, 2008
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Sep 22, 2008
    Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys) ...
    *AF-Key = Additional Functions key = the black button with the star in a head above it.
    1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
    2) Select TEST MODE (press right arrow button 13 times).
    3) Hit -OK-
    4) Select [8] PRINTER TEST
    5) Hit -OK-
    6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
    7) Hit -OK-
    8) Select 0. [INK COUNT].
    9) Hit -OK-
    10) It should return to showing the "8: Printer Test - 8-3 +"
    11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
    hope this helps if you have further problem let me know
    goodluck
    Cleaning the print head:
    At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
    -Remove print head assembly from printer.
    -Remove ink tanks.
    -Use running warm water, wash away the exess ink that is dried around the print head.
    -Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
    (-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
    -Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
    -Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
    -Run Nozzle check, cleaning, print head alignment.
    -All done <3
Machine shows "cover open"
No error code ## 343, but will not print now. How can I change from English to Finish languages in printer?
Jul 08, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon MP36 error ##343
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Hope this helps!
Rehards,
HP
Aug 28, 2009 | Canon SmartBase MP360 All-In-One InkJet...
I have error ##343 on canon smartbase MP390
if this is a lazer printer the waste ends up back in the cartridge. if you have a refilled cartridge you can only refill once, maybe twice then you need a new cartridge
Aug 16, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Jun 17, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon SnartBase MP360 goes through motions of
try to unplugg it install drivers then plugg and reboot and try a teset page.
Jun 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon smartbase Mp 390 ##343 Check printer
can you help my printer canon smartbase mp390 not working gives notice check printer ##343
Jul 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
274 people viewed this question
old marine
old marine
