Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Kenmore Elite Refrigerator error er dh
The refrigerator portion is not really cooling like it used to and the error message of "er dh" shows on the display for a couple of weeks now. It will only go away for a few minutes if you unplug it and plug it back in and then it will return. I've read online that the defrost sensor may need to be replaced. Sears on the phone doesn't seem to know what I'm talking about or locate the part that I would need. Any help? Is the defrost sensor called something else? If I order and try to replace this part, is it hard to replace and will it most likely fix the problem? I just just got my Kenmore Elite Trio delivered yesterday and I had to call for service 5 minutes after that. 1) The water/ ice maker does not work but there is water in the filter. 2) The lights does not work. 3) Now I get this "er dh) message on the lcd panel. I should have done some kind of research on this unit but impulse buying got a hold of me. I bought a lemon!!!
  • 15,935 Answers
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Kenmore bottom freezer refrigerator showing ER on one side and DH on other on temperature control
Hello Mike,
It means that most likely that your Defrost Heater (DH) is not working and one of the following items could be bad;
Er dH Sensor did not get over 40 F Faulty fuse, heater, control board Controller assembly, defrost heater, relay on control board Here is the whole list for your refrigerator;
Kenmore Bottom Freezer Refrigerator Error Codes for 795 Models Sears...
Good Luck!
Rich Lilja
May 12, 2018 | Kenmore Refrigerators
On the door display it says " ER DH " what does
I found this to be quite up your alley... gives you possibilities for DIY repair.
Apr 13, 2011 | Kenmore Elite 44723SS Commercial...
Like others, my Kenmore digital screen is showing an er dh message. We have noticed no performance issues, though. We just can't access any of the screen functions with the error message up. Model...
Hi Jildaw,
With the help of this and other sites I was able to fix my error fairly easily ..I wrote a step -by-step HERE...Hope it helps some.. Was alot cheaper then a service call !
Dec 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
DITIGAL ERROR DISPLAYING MESSAGE?
check your service manual and see what it say about err dh
Mar 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio - Error msg control panel Er dH -
yOU DON'T SAY WHAT THE MESSAGE IS. EITHER WAY IF THERE IS A ERROR CODE USUALLY ONE OF THE FANS ARE NOT RUNNING OR THERE IS A DEFROST PROBLEM.
Dec 02, 2008 | Kenmore 73503 Stainless Steel Bottom...
Error message (?) on display of Kenmore Elite Bottom Freezer Refrigerator
Jul 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer working fine but refrigerator not cooling
Do you have the ER DH error message showing? If so, it is a failed senser, an $11.99 part that many of us are having trouble with.
May 18, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 795.7519
Either you have accidently left the door open at some time in the last few weeks or you have a faulty defrost sensor, initially turn off defrost freezer over night with doors open, turn on following day, unit should start to work within 12 to 24hrs, other wise replace defrost sensor but still deforst. Regards Advisor
Aug 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
3,047 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
