Question about Sharp 32F-630 32" TV
Changes rom Input1 to Input2, Input3 to tv
While watching our tv, it constantly hops from tv to Input 1 or 2 or 3 ... or vice versa.
What can I do?
Please email to southsolana@yahoo.com
3 Suggested Answers
SOURCE: Sharp 32f540 switching input channels
Ladythree,
the problem for your unit is the manual button switches. In the long time it wasnt used. it got stucked and somewhat rusted. This problem can best be addressed by replacing the buttons switches(tac switch).
this should solve your problem.
chris
Posted on Mar 29, 2008
bshldn
  • 736 Answers
SOURCE: Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
Posted on May 05, 2010
Im trying to choose my inputs: (under preferences, Device) begin input1 and end input should be 8, but it only shows 2. Assuming I chose my ASIO4all driver that indownloaded. I can also chose Directsound...
The reason it does not work is because the PV8USB only sends the main mix to the USB. You need a different sort of beast altogether to do what you are wanting.
Apr 30, 2013 | Peavey PV8 Mixer
I just got a 37 inch flat screen. I had it working with my direct TV box. My son pushed a button on the remote and now it will not connect to the direct TV. I need some help.
You will need to look for your input button on the tv or the remote and look at the back of your tv to see where your wires go!!!
You would make sure that the wires go to (input 1) are input2
Then you put your input on input1 are input2 and your wires in input1 are input2 on the back of the tv.
Feb 17, 2010 | Insignia 37" LCD Flat-Panel HDTV
I have cable tv do not know what station to put on to play dvd
Go to your menu or input button and switch to eather input1 or input2 depending on witch inlet u have your DVD attached. there also may be a switch on the back of your DVD player marked 3 or 4 put that to the chanel ur TV is set to for cable most likely cnanel 3
Nov 28, 2009 | RCA Televison & Video
Need to write a simple (no array allowed) to take three inputs from a user and sort it numerically. Not just provide the MAXNUM. via Javascript
in pCode
Var1 = Input1
Var2 = input2
Var3 = input3
If Var1 > Var2 and Var3
Then Var1 is Max
If Var1 > Var2 and < Var3
then Var3 is Max
Else Var2 is Max
If Var1 is Max and Var 2 > Var3
Then Var1 = Max
Var2 = Mid
Var3 = Min
if Var2 is Max and Var >1 Var3
Then Var2 = Max
Var1 = Mid
Var3 = Min
Repeat the various possibilities and you have got your result without arrays
Oct 05, 2009 | Computers & Internet
I have Directvhd and a Govideo 1140 combo. When I tried to play a dvd on input 1 get the movie with no sound, if I go to input2 I get the sound no movie it says progressive scan.
make sure the audio (red, White) is connected to input 1 and the video (yellow) is also connected to input 1. It should be labeled for indentification. Your video is on input 1 but your audio is on input 2 and vice versa. Check your connections again. Make sure your using the red white connections on input 1 for your audio and the yellow for the video on input 1. The above also applies to input 2.
Apr 23, 2009 | GoVideo DV1140 DVD Player / VCR Combo
Trying to hookup dvd
Steps to hook up DVD player:
1. Plug in DVD player
2. Plug in VIDEO cable to back of DVD player
There are multiple video out cable options: HDMI, VGA, RCA
If you aren't sure, use RCA (red, white, yellow tri-plug cable) and plug yellow into VIDEO OUT port.
3. Plug other end of video cable into TV's VIDEO IN port.
4. Turn on TV to the INPUT channel that corresponds with the input port you plugged the video cable into. Usually, this is either VIDEO1, VIDEO2, INPUT1, INPUT2, or channel 3.
May 03, 2008 | Televison & Video
Watching DVD or VHS ...
I could not find the manual for your TV, but I did find one for model number 27N-S50 so hopefully they're very similar. If you DVD/VCR is connected to your TV with composite cables (the RED, WHITE, YELLOW cable set) then you need to change the input mode. There should be a button labeled Input on your remote and pressing it will cycle between the various inputs (Cable, Input1, Input2). I would guess your DVD/VCR is connected to Input 1. If you have lost the remote you should be able to get to the other inputs by using the channel selector button. Tune the TV to either the highest or lowest channel in memory and then press either the CH UP or CH DOWN button on the TV to cycle through the various inputs.
The other thing you should know is that there is a recall on this TV related to the power button. I discovered this while looking for the manual on the Sharp website. Go to this website:
http://www.sharpusa.com/products/support/0,2309,,00.html
Type 27R-S50 in the model box and select Television/Home Theater Projectors in the Product box then click on Get Results and you'll get information on the recall.
Also, if the info I've given about how to select the input does not work, there are links on the above site to help you get the correct manual.
Lastly, I don't get paid for this. I know it's a strange hobby, but I like to help out when I can. I hope you'll take a moment and give a prositive rating if this information has been helpful to you. Nearly half of the solutions I've posted have never been rated. Thanks and good luck.
Jan 03, 2008 | Sharp 27R-S50 27" TV
Lable in Righthand corner on INPUT1 wont go away
When an HD cable box or satellite receiver is connected with HDMI, the information banner in the corner of the screen does not go away when the TV is on that input. The Plasma Display automatically selects an appropriate screen size when video signals are received from a connected HDMI equipment. The TV's attempt to search for aspect ratio information through the HDMI connection can cause the information banner to stay on the screen, if the data is not found. To turn off the Auto Size, please follow these steps: 1 Press HOME MENU. 2 Select (Option). ( / then ENTER) 3 Select (Auto Size). ( / then ENTER) 4 Select (OFF). ( / then ENTER)
Aug 24, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Sharp 32F-630 32" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
