How do you know if you have a Progressive Scan TV? We are having problems playing DVD's from video stores. It will play the previews, but when it gets to play the movie, it doesn't play. I can play them on my computer, but not on my new Philips DVD player.
    Novelist:
  • 116 Answers
Well, a progressive scan TV displays in the same resolution as a normal interlace TV. It's very hard to tell the difference in all respect.
Progressive rewrites every single line/pixel on the screen. Interlaced simply skips a line and rewrites half of the lines every frame. So, progressive can show higher quality, but interlaced was more predominant as it was easier to create for TV makers in the earlier days.
Most of today's better televisions are strictly progressive and you won't have any problems.
I'd try a different DVD player with the selected titles and see if the problem persists. It could be the TV or the or the player itself. If the titles work in another DVD player. Try a newer television and see if it works there.
Hope these ideas help.
Posted on Sep 21, 2008
My zenith xbv343 dvd vcr combo has a problem when i put on a dvd it says progressive scan mode i cant see nothin else
Hello
That means the DVD you put into it to play has recordings with "progressive scan" mode. You have to change the mode of the DVD and TV which you wants to see to Progressive Scan mode to see the disc content. OK.
May 09, 2011 | Audio Players & Recorders
Progressive scan turned on - how do you turn it off?
I'm not very familiar with this namebrand on electronics, but they are all the same anyways.To check if this function is on, usually the player's lcd screen would have a "P", "PROGRESSIVE" or "P-SCAN" on it. First, make sure you remove all dvd's or cd's from the player, then look for a button on the remote, or the unit itself that say's "P-SCAN", "PROGRESSIVE" or "RESOLUTION", once you find it, push it, sometimes they would indicate the resolution on the player's lcd screen (480i, 480p,720p,1080i, 1080p), if not, on the tv itself. The resolution you are looking for is 480i for the type of cables you are using (composite RCA). Give it a try, and let me know how it goes...
Jun 09, 2008 | kawasaki 5-DVD Home Theater System - 1152...
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Thanks!
Patsy
Dec 29, 2007 | Goldstar GBV241 DVD Player/VCR
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Progressive Scan
On 12/29/2007 at 1135pm, I found the solution for yours and my problem. Here is what you need to do. I did the same thing and couldnt get video. If you set Progressive Scan to ON in error , you must reset the unit. Play your dvd, then press "STOP" to stop the disc from playing. Hold the stop button on the dvd player for approx 5 seconds before releasing it. The video output will be restored to the standard setting, and a picture will once again be visible on a conventional analog TV or monitor.
Oct 14, 2007 | Zenith DVB312 DVD Player
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
DVD no video
make sure that the wires are connected properly if they are then take the set to a tech you are having a problem in your video circuit.goodluck.
Apr 01, 2007 | JVC HR-XVC33U DVD Player/VCR
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
