My damn Compaq labtop turns on, shows the first screen with the compaq insignia but then shuts off. It turns back on automatically buuuuuuuut i guees it remembers that its fucked up n turnz back off. This proccess can go on for ever. Im about 2 take a stroll 2 the slaughter house. plz help
  • 781 Answers
1. the cpu may be running to hot.. do you hear a fan going on when you start your system?: as soon as you see the compaq message press f2 (I'm not sure if that's the key.. usually it's indicated at the bottom of the compaq screen then try to go into the the cmos/bios program and look for temperture information on your cpu... should be below 50 ...
2. it could also be a virus: did you install something recently?...
3. it could be a hardware problem.. did you install new memory recently.. try removing the new memory stick.
4. laptops are hard to troubleshoot so you may want to take the computer for service or get in contact with HP's representative online or over the phone, they may give you more pointer of what you can try or what you can do.
any other approach that you may take may require for you to get get the hard drive out to back up you data using the drive in another computer (may need to get an adapter or a enclosure with usb adapter but is possible) then reinstall os with the revorey partition that may still be avaliable by pressing and f key as directed also in the first compaq screen that you get to see.
Posted on Sep 21, 2008
My labtop scren will not come on.. compaq presario v6000
Did you change the "DISPLAY SETTINGS" on the system ?
Jan 26, 2013 | Computers & Internet
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Black sreem on a compaq labtop cq50-215NR compaq
1 disconnect the AC adapter and remove the battery from the laptop
2. Press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter to the laptop
4. turn On the notebook and check.
If the issue persists, restart the notebook and press F10 to check if you see the BIOS screen. If you cannot see the BIOS screen then the issue could be hardware issue and your laptop needs to be repaired
Jun 16, 2010 | Compaq Computers & Internet
When I turn the laptop on it powers up but there is a black screen. It's a compaq nx9110
Shut it down. Take the battery out. Unplug it. Leave the battery out then turn the computer back on. If you still have a black screen there is a hardware problem. If you have an external monitor connect it to the laptop and switch to show on external monitor. If you can see externaly then problem is cable or screen problem. If you can't see external picture then problem is most likely a chip on the motherboard. Video chip problem common on hp and compaq laptops.
Nov 07, 2009 | HP Compaq nx9110 Notebook
Compaq 1200 Series showing only numbers and letters at bootup
Its due to the problem in THe RAM ..try to replace the Ram ..
Thank you for choosing Fixya..
Mar 15, 2009 | Compaq Presario 1200XL104 Notebook
Compaq Presario CQ50 Labtop, makes awful constant beeps
If you shut it down when WinFlash was running, then bad news - BIOS corrupted. This means faulty motherboard. Solution - replace motherboard.
Mar 11, 2009 | Acer TravelMate 2480 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Compaq 1275
possibly this could be a lid switch issue, check you lid switch settings in power manager.
Oct 07, 2007 | Compaq Presario 1275 Notebook
Labtop lights up no work
change the battery...
another solution, try to re- install OS
Sep 24, 2007 | Compaq Presario 900 /1500 Series EVO...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
