Question about Gateway (4000531) Motherboard
Gateway GT5228 booting problem
I have a Gateway GT series 5228, and when I turn it on, the fan starts to go and I hear a click, a click that always happens when the computer boots, but then the monitor says there is no signal, and the fan keeps running with no boot. Also after I try to turn it on after a couple of unsuccessful tries, it actually boots and the machine works fine.
I have already sent it to Geek Squad and they replaced the Thermal Paste in my unit, but when i hooked it up and turned it on, it did not boot until the seventh or eighth time i tried, with the same problems as listed above.
  • mffngrl Nov 18, 2008
    My screen went black. I could hear the fan running. I tried using other monitors - black screen but fan going. Put in another hard drive, black screen. Put in a video card and it came up for a bit and recognized both hard drives, then went to black screen again.
    Lynn
  • sandy08 Feb 19, 2009
    Anybody ever come to a definite conclusion on this problem? I have the same thing. When I power it on the fan starts, the CD drive clicks but then nothing happens and the screen remains blank with no signal. Almost as if the Bios is hanging.
    Replaced power supply and no improvement. If I keep trying to power it up it will eventually start but it may take 5 tries or several days before it will start up. Totally random. Once it's up it works fine unless I have to reboot.
  • 22 Answers
"Also after I try to turn it on after a couple of unsuccessful tries, it actually boots and the machine works fine". This maybe cause by the hardware problem. And it usually caused by the motherboard. Changing the motherboard unit may solve the problem. But make sure you've already done the basic test on all of your hardware before changing it with a new one.
Posted on Sep 21, 2008
How can i reset my gateway gt 5228 to factory settings?
Hi blainholdens,
You cannot delete everything on your hard drive if it is your main operating system drive. If you don't have a CD with which to install your operating system you will have to install the hard drive into another PC as a secondary drive, open 'My computer', right click on your hard drive and select the 'format' option from the drop-down menu.
Formatting the hard drive is effectively erasing all data from the disk and making it active and preparing it for starting new.
Best wishes,
Graemevm
Jan 12, 2012 | Gateway GT5228 (7156) PC Desktop
Gateway Desktop GT5228 comes up with "Disk failure - insert boot disk". I cant locate boot disk due to moving. Will I lose data on hard drive???
Go to ur BiOS and check if ur motherboard can read the HD and set the boot up to HD first!
Tell me afterwards!
Nov 30, 2010 | Gateway GT5228 (7156) PC Desktop
Gateway 5228 wont boot no lights on keyboard
does it load the bios screen? Does it get to the windows load screens if it does go to the bios screen? Does the computer power on at all?
Sometimes what happens is the bios chip can be faulty or die and this will have to be replaced to fix the issue. If the computer is not powering on then it is more than likely a power supply issue.
(just in case, you might want to make sure that all of the adapters that come from the power supply are connected to the motherboard as well)
Sep 30, 2009 | Gateway Computers & Internet
GT 5228, GATEWAY
What happened is your video card has burned out. If you are still using the video connection that is on your motherboard then what you need to do is go out and buy a new video card that will go into your pci slot inside your computer and then you'll connect your monitor to the new video card and your picture will be back up in no time.
Sep 29, 2009 | Computers & Internet
Gateway GT5228 Will NOT Startup
TAKE OUT YOUR MEMORY CHIPS,AND INSERT 1 AT A TIME AND TRY.
IT COULD BE YOUR RAM THAT IS FAULTY THATS WHY ITS DOING THIS
Jul 04, 2009 | Gateway GT5228 (7156) PC Desktop
Fan runs but will not boot.
Remove all external devices first like printers etc and then try again.
If it doesn't work then you will have to open the computer case side panel so we can start troubleshooting some parts.
If the machine has warranty then you should rather take it back before opening it.
when the case is open first make sure the power is disconnected and the case must be laid flat on the ground.
look for the memory RAM ,if you have two of them then try booting with one and vice versa ,if you only have one stick then remove it and reinsert it into the next available slot.
If that doesn't help then disconnect the data and power cables going to the harddrive and CD ROM drive.
The last option is to change the power supply ,if it still doesn't start then its most likely a motherboard or CPU problem.
Good Luck
May 06, 2009 | Gateway GT5228 (7156) PC Desktop
My gateway gt 5228 has power boots up but I have no picture on monitor and the keyboard doesn't work. Both monitor and keyboard work on another computer. what is wrong with PC
First disconnect any external devices like printers etc that you might have plugged in.
If that doesn't work then it's a problem inside the box it can be the power supply ,motherboard ,memory ,CPU and others.
If the PC has warranty then you should take it back.
If you are comfortable in opening your computer then we could try more advanced troubleshooting ,let me know if you want to try it.
Mar 28, 2009 | Gateway GT5228 (7156) PC Desktop
Gateway gt 5228 desktop when on there is no picture and keyboard
my 5228 was under warranty when the same problem occurred. the motherboard was replaced at least twice. six months later, I have the same problem but now am out of warranty. so try replacing the motherboard. am going to try it on my own only because I have so much info in that compter.
Gateway GT5228 PC Desktop
Boot into safe mode and see if you can either roll back the driver restore the computer to the date right before you downloaded it.  the link is for directions on how to boot into safe mode.   Another option , if you have on board graphisc alos is to hook up the monitor to the onboard  turn it on in BIOS and change the driver for the card using the onther graphics.
http://www.pchell.com/support/safemode.shtml
Jan 28, 2009 | Gateway GT5228 PC Desktop
Gateway (4000531) Motherboard Logo
539 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
