Question about Dishwashers
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Posted on Nov 11, 2008
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Heller dwh16 element is it easy to replace
Not really , you will need to take the draws out to replace it but it save $$ doing it yourself :)
Oct 29, 2013 | Fisher DS603W / DS603B / DS603I Dishwasher
Hi - have a DWH16 Heller
disconnect the element and use a test meter across the terminals of the element to check for resistance, no reading or OL will confirm if the element has failed.
Jun 16, 2012 | Dishwashers
Dishes in upper tray coming out not so clean!
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 09, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
NOT CLEANING PROPERLY
Hi
Thanks
Rylee
Dec 03, 2009 | Whirlpool Dishwashers
Top rack won't clean
Hi
Thanks
Rylee
Sep 20, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
HM603222A moffat dishwasher...not cleaning dishes. Food particles are being circulated around and drying on dishes
Hi
Thanks
Rylee
Aug 29, 2009 | Dishwashers
Kenmore dishwasher does not clean
Hi
Thanks
Rylee
Aug 04, 2009 | Kenmore Dishwashers
Dishwasher does not clean the dishes properly
Hi
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
431 people viewed this question
Top Dishwashers Experts
