Question about Hotpoint Dryers
How to hook up the outlet plug on the hot point dryers
    Genius:
  • 1,122 Answers
White always goes in the middle!!!!!!!!!!!!!!,green on top on green screw,black on one side and red on a four wire outlet,on a three white in the middle!!!!! black on one side and red on the other-mike
Posted on Sep 21, 2008
I am trying to change my miller welder 4 prong plug to qa 3 prong to match my dryer outlet ? which wire goes where ?
On 4 wire outlets the neutral and ground wire were seperate on 3 wire the ground and neutral are combined so hook up the 2 hots (black&red) as before on the 2 outside terminals and combine the green and white together onto the center terminal
Nov 12, 2011 | Whirlpool LER5636P Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Plug does not go into outlet. Three blade plug with one "J" shaped blade. The outlet has three straight hole to acommodate three straight blades.
Replace the power cord to accomodate the outlet you have. You can purchase them at any hardware store for about $20. This is the easier option than trying to replace the outlet. To replace the cord follow these steps:
1. Remove the access cover on the terminal block on the back of the dryer. This is where the existing power cord is installed.
2. Remove the existing power cord from the terminal block.
3. Remove the power cord restraining clamp (if equipped). This secures the power cord at the entry point on the back of the dryer and prevents it from stressing the terminals and prevents chaffing of the outer insulation on the power cord. NOTE: Its a good idea to have this installed for safety reasons.
4. Remove the old power cord and install the new one following this color scheme at the terminal block:
RED (Hot) - 120VAC
BLACK (Hot) - 120VAC
WHITE (Neutral) - 0 VAC - Should be connected to the terminal block and grounded to the equipment cabinet via a grounding strap.
NOTE: If the power cord or wires at the terminal block are not color coded, the outer two wires (LEFT and RIGHT) are the two hot leads. The center conductor is Neutral.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Dec 22, 2009 | Dishwashers
How do I hook the electric cord to the dryer?
Most electric dryers are 220 with a neutral. Inside the machine, they use one leg and neutral to power the timer and the light both of which are normally 120 V
Do you have a volt meter? And do you have a plug in the wall into which you want to plug the dryer?
If you have a volt meter measure between any two of the three slots in (or on) the wall outlet. You will get 120 VAC or 220 VAC. Measure the remaining slot you didnt measure and any other slot. You will get the same results. at the common point where you got 120 (120 from both sides, that is neutral. Inside the dryer should be an indicator of where the hot legs gl as well as the neutral. You can check which wire supplies which blade with a simple contuinity test to be sure if there are no marks on the wire.
I hope this helps
Sep 07, 2009 | Maytag PYE2300AY Electric Dryer
Hello, I have a Kenmore 80 Series. Washer and Dryer. Bought it from someone on Craigslist. How do I hook them up? Is there a manual any where out there?
Connect your hot and cold water pipes to the washer. Place the drain pipe into a sink or direct drain feed to your sewer system. Plug it into outlet. Dryer - plug it into your 220 line outlet. If the plug is not the same as your outlet you can find instructions on lline with pics on how to change a 3 prong plug to a 4 prong plug and so on...:)
Jun 07, 2009 | Kenmore Dryers
From three prong to four prong
Hello There,
your hooking up 2 Hots 1 Neutral and 1 Ground
240v
you need to consult a electrician for reason that 240 is a very high voltage and will kill you.
your outlet has to match your plug and how its wired into the Panel
Double Pole Breaker 50amp no less
2 hots go to breaker from outlet red / black
1 neutral goes to neutral bus bar in panel from outlet
1 ground goes to ground bus bar in panel from outlet
that equals your four wires
Mar 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer is turning but no heat is coming out
If you had a 3 prong originaly you probably have only 3 wires to work with, either a red and black and white or a black and a black with a red stripe and a bare stranded wire. The black and red are ALWAYS the 2 hot wires 230 volt. The white or bare are the neutral / common wires. If you only have 3 you will need to get your equipment ground from a cold water line to the 4th prong.
Another option leave the 3 prong in the wall and install the old 3 prong pig tail on the new dryer then ground the frame of the dryer to the nearest cold water line. The water line must be metalic for this to work.
Dave
Mar 15, 2009 | Whirlpool Dryers
I have whirlpool electric cloth dryer Model # LEC7848DZ1. Serial # MF0902194 I doesn't start at all. no heat no spinning. Please help. electic durrent is up to outlet, so electicity is not a proble....
Its possible that the thermal fuse is bad and needs replacing. Could have been caused by partial plugged hose to include where it hooks up. When it senses that its too hot it will blow that fuse. Hope this helped.
Trying to wire a 3 wire dryer from panel box to dryer plug
Sounds like you have a 10-2 NM wire. One black, one white, one bare copper. At panel box, black to one hot terminal of breaker or fuse holder (L1). White to other breaker terminal or other fuse holder (L2). Bare copper to the grounded neutral buss bar.
At the dryer the bare neutral goes to the center terminal, the other two go one each on either side, it won't matter which way. Hot Neutral Hot. The neutral terminal of the dryer should have a wire or metal strap connecting it to the dryer frame if you are not using a four wire supply.
Oct 22, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
