Question about Kitchen Ranges
Kenmore free standing range
I have to convert my new kenmore range to LP, but I've lost the instructions. Where can I find the instructions on-line? Or do I need to go back to Sears and try to get one from them?
  • davy916 Sep 21, 2008
    I have the brass fittings, but is that all that I have to do? I was thinking that I had to do something else with the regulator on the back of the stove.
You might have to adjust the flames,but that is under the top behind the knobs,let me know,mike
Posted on Sep 21, 2008
    Genius:
  • 1,122 Answers
Look on the bad of your stove,there should be four braas fitting,on a piece of cardboard,these are your fitting for lp gas change over,just unscrew the old one and replace with these,let me know-miike
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of soot...how fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Convert maxitrol regulator#rv47cl natural to propane gas
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Nov 18, 2013 | Kenmore 72132 / 72134 Gas Kitchen Range
Looking for manual for kenmore electric range part#316902006
Many Kenmore appliance manuals are available from Manage My Life (http://www.managemylife.com/mmh/owner_manuals ) From that site, I found this manual: http://www.managemylife.com/mmh/owner_manuals/133298/KENMORE-Free-Standing-Electric-1008706L?brand_name_search=316.902006 . This manual applies to the 790.9021* and 316.902006 free-standing electric ranges.
If this isn't the correct Use and Care Manual, please check your model number. Kenmore appliances usually have a 11 digit model number (3 digits, period, 8 digits); you've provided a 9 digit code.
I hope this helps.
Mar 08, 2012 | Kitchen Ranges
Changing 5 orifices to convert from natural gas to lp but I can't see any indication on the burners as to which orifice goes where ??
You will need the installation instructions to complete this as it is important to make sure this is set correctly.
I would need a complete model number to attempt t locate this information for you, it mainly depends on who built the unit for Kenmore, as Kenmore builds nothing them self.
I would like to help you, please get back to me
Aug 30, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
How do i convert my 790.71011200 kenmore range from natural gas to LP?
After looking high and low for a conversion kit I finally looked up the installation manual for your range. AND gues what!! you have everything you need there!! Just follow the instructions in the installation manual for conversion over to LP.
Download the installation manual here if you do not have yours. The instructions are in the back pages 9 & 10.
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0207026.pdf
Have fun!!
Heatman101
Jan 19, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Need to convert from natural gas to LP. How?
I converted a gas range several years ago, and all that was required was that I had to 'seat' all of the orfices - or tighten them down so that they are completely seated (do not overtighten!). It has been working great for years!
Sep 07, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Shabbat mode intructions for Kenmore free standing oven
you can download a manual from the manufactures website/The sabbath mode is in the options or set-up button.
Oct 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
