Freezers Logo
mark Posted on Oct 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge freezer not working after power cut. lights go on inside but doesnt seem to freeze or make ice, help please
AJMAL KHAN
Level 2:
  • Expert 388 Answers
  • Posted on Jul 20, 2016
AJMAL KHAN
Expert
Level 2:
Answers
388
Questions
0
Helped
110161
Points
869
Check the thermostat setting and pre fuse
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Oct 14, 2011
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
580025
Points
4327
This is a reoccuring probelm and it leads to the "Control Board" (Mother Board, Circuit Board") as the culprit
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 • Freezers
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
2answers
Freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 17, 2010 • Freezers
2answers
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 • Freezers
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 • Freezers
ICE BUT NO CUBES
look inside ice bin to see if auger wheel is broke,sometimes the plastic wheel cut and break,hope this helps-mike
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 • Freezers
BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Dec 19, 2007 • Freezers
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
