Question about Ovens
NEFF Hob The heat ring goes on to required heat, stays on for a while then goes off. This just happens to one ring....the other three are ok. Many thanks for any help you can provide.
Change the relay
Posted on Sep 21, 2008
Have a neff t1213xo, what does black grey and brown wires stand for?
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Nov 24, 2014 | Neff Ovens
What size cable and fuse do I need to run a Neff oven 3.68kw. and induction hob 7.2kw together ?
Divide the total load by the volts available ie. 11kw by 240v or 110v, the result is current in amps. You need a cable of a suitable cross section to transmit that amperage. There is also a distance calculation to be considered as this affects the available load. Get a sparkie to guide you as to correct sizing.
Nov 04, 2014 | Neff Ovens
Zanussi hob can't turn off full power on one ring
the regulator is faulty you will have to fit a new one fairly easy task let me know if you want more help
Apr 17, 2012 | Zanussi Ovens
Can NEFF oven be connected using a three pin plug on an independent oven circuit
If is a bog standard single oven then yes, if it has a self clean function or a rapid heat up function then generally no as the current draw would be to high for a 13amp to cope with, if you need model specific verification ring number as per linkhttp://www.neffcustomerservice.co.uk/Neff/CustomerService.html
Nov 26, 2011 | Neff Ovens
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
Element / burner / hob is overheating on an electric oven
If three of the rings are not responding to adjustment, then I would say yes, you have faulty regulators;It is a fairly straightfoirward job to replace if you know how to access the controls
Dec 05, 2008 | New World E70DOa Electric Double Oven
NEFF HOB
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety. Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Oct 18, 2008 | AEG B1180-4 Electric Single Oven
Ovens Logo
76 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
