U push other button some time release ur powerbutton
Try pulling out the button by pinching it outside through a pin after that just spray a bit of wd-40 (a greasy rusty cleaning solution)that will smoothen the button movement to avoid further stucking up.this a common problem and gets resolved by spraing the wd-40.
feel free for further queries
thanks.
Does its remote work to power On and Off?
If yes, power can be switch on-off by remote and if you want to shut off tv completely, just unplug it from AC out let.
It is simple and easy way instead of opening back cover and do it yourself job.
Thank you.
If your TV is under warranty you bring it to the dealer, If not then find a authorized service center.Your problem is very easy,if you know how to open the back cover ,it is only broken power switch socket you only stick it with a glue epoxy,so it will works again.
Hope it may help you;
Regards,
VOTIT
If this is out of warranty then its better to contact the local tech to get this fixed.
