Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Hc-p4752 black screen when powered on.
You answered a question for me the other day about this tv (hc-p4752) not turning on at all after repair and you suggested checking to make sure solder wasn't bridged. It was and we fixed that so, now it powers on but it just has a black screen. We just can't seem to get everything right. If you have a suggestion on what to do next , I'd really appreciate it.
    Problem Solver:
  • 6 Answers
Glad i could help ...now the black screen .. remove the back turn it on and look at the actual tubes
the base of the tubes should have a reddish glow if not the set isnt fully on look at the top of the tube if its on you should see a box or a dot etc
if both conditions above are true then you have damaged the stks you will need to replace them again
you can order from here $7.99 each http://www.electronix.com
remember to solder carefully stks do not take shorts well
if you dont see anything in the tubes you may have damaged the regulator too if you have a multimeter handy (and you know how to use it)while the set is running check (pins 15,18) for +28 volts {pins 16 ,17 and 19} for -28 volts if you dont get around those voltages you will be replacing the regulator too its probably an str (something or other) look around where the power cord plugs in for a big transistor looking thing..
good luck
Posted on Sep 23, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
? 3:16
Dec 20, 2015 | LG Televison & Video
Is there a reset button on a vizio lcd 32 in flat screen tv and where would the fuse be located what happen was my husband accidentally touched the usb where it says sevice with a wire and the tv just...
Hi Kaycee.
I suggest you try to reset the power to the TV:
Start off by turning the TV off and unplugging it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
Hopefully this will get it working for you.
If this does not solve the problem, you can go to the online video, "How to Power Cycle a VIZIO TV" - see attached video.
Reference is
https://answers.vizio.com/hc/en-us/articles/200132879-How-to-Power-Cycle-a-VIZIO-TV
Hope this all helps you
Mar 04, 2015 | Vizio Televison & Video
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Tv won't turn on after repair
the first two things to check is to make sure none of the IC pins arent bridged with solder, and the other is to determine all wires are connected correctly and firmly.
Sep 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
Replaced ics, no power
i have one on my workbench right now please check the jumpers you unplugged especially the one on the far left corner (goes to front panel) the one behind the stk 392 010 you replaced (very easy to miss)
take good lighting and make sure every jumper is plugged in
skip this if your set was working but if it wasnt check the fuses and fusible resistors
third if all that fails check your soldering make sure the joints(on the stk's ) are all good and shiny and the joints on the heavier components especially the line output transformer the big black plastic thing on the right of the stk ic you could have loosened it [UNPLUG THE POWER CORD FIRST]
Cant find parts
The resistors are 3.9OHM you can get the ICs you need as well as the risistors at the following link. They also provide free instalation instructions and free online instant messageing with a tech when you do the actual repair. If your model is the HC-P4752 you will need two STK392-010 Convergence ICs as well. heres the link.
http://servicemanuals.vstore.ca/
Apr 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Westington LTV-27w7 HD black screen
ICheck the power supply connections make shure tht the plugs are seated correctly. The power supply isreplaceable as a complete uitand you have to return a repairable unit.
loumargo
Allied electronics
loumargo@verizon.net
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
