Question about HP PSC 750 All-In-One InkJet Printer
Scanner faliure Each time I try to use my scanner it reads scanner faliure. Turn off and turn back on, This does not work. It continue to read the same thing and print out pages that I do not recongnize.
    Scholar:
  • 116 Answers
The cables connected internally to the scanner unit had gone short some where in between you have to check it manually by opening the device .and then remove the cables and replace them with a same length cable.you can get the cables from any electronic shop who keeps printer assessories.and then it will work properly as normal.
Posted on Oct 05, 2008
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
Scanner error message
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
My hp laserjet 3330mfp reports a scanner bulb is warming up and it never goes off. I have tried to unplug then plug back in. The printer works fine.
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Oct 20, 2010 | HP LaserJet 3330 All-In-One Printer
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Mar 03, 2009 | Ricoh Aficio 450 Copier
Scanner Faliure
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
8011
Jan 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Troubles with connection?
if this item is second hand it may have been associated with more than one scanner, You should be able to log into the base station and read the error logs, and check the scanner associations. you could always try a factory reset, but you would have to re-associate the scanner and configure the base station again Gareth
Jul 12, 2007 | PSC QuickScan QS6500BT (QS65B3040100401)...
HP PSC 750 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
