Question about Frigidaire Refrigerators
Not cooling i have 70 psi of freon is that enought
  • 1,122 Answers
Look inside the frig. to see if you can see it on the model decal,also look on the compressor.let me know-mike
Posted on Sep 21, 2008
My refrigerator does not cool enought and leaks at the back because the pipes next to the compressor are frozen
You must have a freon leak somewhere. Because from the indications you gave it sounds like you are low on freon.
Aug 13, 2011 | Coldtech J1GR-05S Commercial Beverage...
AC won't cool, clutch continuosly snaps on and off.
The first step is : check if the car is lower in freon.
because when the system is low . the cycling switch turn off the compressor when the pressure goes lower that 25 psi.
Get a Can of freon and charge for the LOW side service port.
But if you note that the system is full on freon.
make a BY PASS on the CYCLING Switch.
Is located on the Filter dryer.( acunmulator)
and see if the a/c is cold enought.
OK.. I hope this help on your problem...
Jul 26, 2008 | Ford F-350 Cars & Trucks
I replaced the compressor on my refrigerator. There were no tags as to how much freon the system takes. So I added enough to bring the low side to 72 psi w/ a cabinet temp of 70 degrees. The high side...
**** boy. 72 psi on the low side? It ain't an air conditioner. The low side should be never over 5 PSI. The whole system holds only arounf 4 ounces. What were ya thankin? LOL WOW you will be lucky if the reed valves ain't blown in the new compressor. Go ahead and evacuate the system. Pull that ****** down to as close to negative 30 as you can and then shut her down. Just crack open the freon a hair and let it SLOWL:Y build to no more than 5PSI on the low side.
Feb 17, 2011 | Refrigerators
Water flow adjustment
first what type of freon does this unit take
Mar 31, 2010 | Heating & Cooling
Indoor unit coil air temperature 60F - 70F after R22 charge..
Clean the outside and inside coils and filter. This could be an air flow problem
Aug 21, 2009 | Sanyo Split System Air Conditioner
Not cooling
your low for 134A should not exeeed 45 Psi and highs for 134A shouldent get above 300. When your replacing stuff are you cleaning out the residue from your evap and condensor prior to reinstalling Freon?allso adding oil. and vacumeing your system prior to charging helps to get all the moisture out. In high humidity its crutial for optimal cooling and when system is open to the humidity for some time it gets loaded with water and vacuming can sometimes take as long as 10 hours
Jul 30, 2009 | 2005 Dodge Durango
I have a 99 chevy suburban that won't cool past 60 degrees and when idling is at 70 degrees. I have replaced the a/c compressor, orfice tube,the accumilator,rear expension valve, and fan clutch. My low...
These numbers are a little high depsite the high ambient conditions.Amazingly enough ,automotive low side suction pressure will equal the degrees its putting out at the evaporator coil...for instance,70 psi low side pressure will produce about 70 degrees of cooling. At 300 psi on the high side(which is high) this is about as low as the suction pressure will need it to go lower.I would probably be concerned with the freon level as a slight overcharge could boost these numbers.Poor air flow through the condenser can also create a higher head pressure than desired.If possible,I would evacuate and re-charge the system with the correct amount of 134a refrigerant. Try to get those pressures lower...about 250/50 would be a decent pressure value in this ambient condition.Verify good airflow through the coils and pay close attention to any foreign debris like plastic grocery bags or wrappers covering the coils...Ive even seen these make their way between the small gap between the condenser and radiator so use a light and inspect carefully for this.Air flow through that condenser coil is vital and any deficit there will create high head pressure which obviously causes high suction pressures....good luck
Jul 29, 2009 | 1999 Chevrolet Suburban
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
AC is not cooling
I would say you have a freon leak. May be the outside unit is not running now because the low psi switch has it off because it does not have enought freon.
Apr 07, 2009 | Haier Air Conditioner
Room not cooling
Install linetap service valve. purge gauge lines, charge it to about
60lbs psi @ 70 degrees ambiant, 70psi @ 80 degrees ambiant. Etc.
Mar 18, 2008 | Samsung AW0603B Air Conditioner
Refrigerators Logo
70 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
