Question about Gateway Computers & Internet
I need to transfer my settings and programs from my old laptop (using XP) to my new laptop which is using vista.
  • 781 Answers
Try start>all programs>accessories>system tools>file and settings transfer wizard... I'm sure it will work across xp and vista. (with settings in particular as files should probably be ok). but that's where I would start.
Posted on Sep 21, 2008
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Transfer XP files to Vista: i am having a nightmare of a time trying to transfer files from my XP computer to my new Vista computer. I tried using an Easy Transfer Cable fo Windows Vista. The driver CD was...
yeah u can use remote desktop connection.which u can find in start->program->accessories->remote desktop.first u need to connect the two computers using lan wire(ethernet cable)....for detailed help ask me on satvir_kambo@yahoo.com
Sep 01, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Are XP to VISTA transfers doable w/ V 6.2.10.14?
It is not advisable.
Relocator is not 100% guaranteed to even work xp to xp
You are better to use the Vista Easy Transfer utility which operates similar to the XP File and Settings Transfer wizard. That should get your documents email etc.
I have only ever used it a couple of times and was not impressed.
I have also seen quite a few reports of other users having problems too.
That said people do use it and it can work.
I have used the vista transfer tool and been quite impressed even though it can be a little slow on occasion.
Aug 25, 2009 | Eisenworld Alohabob PC Relocator Ultra...
Can I use PC Relocator to transfer my programs to external drive?
You can but this software is certainly not the best.
You may find problems with the move.
For XP to XP it may work OK but for variations of XP / VISTA moves I would not recommend it.
Although it takes longer often it works out better to use the files and settings type utilities built onto windows xp or vista.
and properly install any programs you need before you do the transfer.
Also consider that you are more likely to transfer unwanted items with this program. It is not unusual to end up with garbage from your old computer on the new one.
Aug 11, 2009 | Pearson Software Consulting Alohabob PC...
Vista machine doesn't recognize drivers so can't transfer files from old PC to new one (with Vista). Any updates?
what do use to transfer? usb stick or network connection?or cd/dvd-r?
what os does your old machine have?
if both machines have valid and functioning OS(winxx) and both have usb 2.0 port,
and you are transferring just back-up of personal data (doc's, mp3's, save-games etc., use) that amount up to less than 1 GB, try using usb-stick or empty mp3-player for file swapping.
else burn the files from old machine using the hopefully available cd/dvd-burner in it and transfer to newer.
for easily transferring the whole content of old harddisk unaltered,
set up asmall win-home-network using dsl/lan-cable plus crossover adaptor
(wire up both machines to one-another) and stream old harddisk content to new machine
is it laptop to laptop-transfer and you are somewhat familiar with hardware?
remove harddisk from older and put into new one!
by the way: if you can have win xp pro installed on newer machine for same or less price of win vista, try to get it(you do need a bit computer expertise - but we all like learning -don't we?
good luck, if not satisfied or too much options for one time, just comeback to me!
sincerely yours
Jun 16, 2009 | Eisenworld Alohabob PC Backup for PC
Transfer data from XP to Vista using DVDs
There might be an issue with the DVDs, I suggest restarting the process with your anti-virus program turned off on both PCs and a new DVD. Make sure you delete the MigWiz folder from the XP machine and re-start the process.
Good luck and re-post if you need anything.
Mar 14, 2009 | HP Computers & Internet
Unable to transfer files from Vista To XP
I know how to do it all you got to do is go to start click on network and copy ur files from vista pc name to the xp name and your done i wish i could make a video but i don't have a camera. if u have any questions email me xbox_chap@yahoo.com
Jun 16, 2008 | Western Digital My Book Essential Edition...
I have purshased Belkin Easy transfer cable to tranfer data between my old Laptop and new one (old using windows xp new one vista home)I does not appear to work.I have loaded the CD as requested but idoes...
use the Files and Settings Transfer Wizard instead of the Belkin software. It's pretty straight forward in the steps for moving files to "new" computer.
Jun 09, 2008 | Computers & Internet
Transfer of contents from old laptopto new laptop, and cost
with xp and vista, it's an option in the programs listing..File Transfer wizard..follow those instructions
May 11, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
