Question about Zanussi ZBF660 Electric Single Oven
Spanner symbol After a power cut the stove has a spanner showing in the digital screen. The stove was working perfectly before storm. Is the stove safe to use (it is still working). I do not have a manual.
Whirlpool super capacity 465 stove
If you have an element that stays energized with the power off if it's 208/240 the heat relay on the control board is fused if 120 could be a board again or grounded
Jan 30, 2014 | Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Oven is cutting out after leaving it does come on again. Do they have cut off switches,
Hi ebttw,
Yes they do, these cutouts are situated on the inside attached to the outer cavity of the stove.
If the outer cavity gets too hot, it cuts out power to the element (sometimes the whole stove) to prevent any damages. If the temperature then goes down, it then allows continuity to go through it again.
I'd suggest checking your temperatures with a digital thermometer (Can be purchased almost anywhere), it could be the start of a faulty Thermostat.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 03, 2011 | Stoves Premier 900DCa Dual Double Oven
Power surge damage during electrical storm on 01/01/2011, no display plus oven control erratic.
I'd be contacting my home owners insurance company and local power company.Local power companies will offer to repair for free in most cases.
Jan 06, 2011 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
Digital display is not working
you need to check the main power and see if the power is orrect if so replace the electronic control better known as the clock timer
Jul 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't work. Stove still does.
The circuit board on the clock was possibly damaged by the lightning storm. Need new clock.
Sep 20, 2009 | Ovens
I have a spanner symbol lighting up on the digital display occassionally. what is this?
This normally means you have a problem with the cooker,sounds intermittant, but I would suggest you have it checked out.
Aug 11, 2009 | Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Zanussi ZBF660 Electric Single Oven Logo
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
