Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Not dispensing Ice or Water thru door
My Superba ice maker still makes ice but when I try to get it to dispense either ice or water I get no sound and no product.
  • 1 more comment
  • Anonymous Sep 21, 2008
    I've got the same problem as itcsjh, except mine will dispense water, but not the ice. Makes a quiet clicking sound, but does nothing.
  • TXUSA Oct 04, 2008
    I was without power for almost 2 weeks due to hurricane Ike. My icemaker will make ice, but the door dispenser will not work. It seems like water got down into the metal rod beneath the ice bin and freezes up. Any ideas on how to fix?
  • fredatacare Oct 07, 2008
    I also do not dispense ice or water and the light will not go on; happened after I removed Ice tray to dump it and put it back in.
    problem seems to be related to the screw mechanism that dispenses the ice. I can remove tray and turn the dispenser from the back and then it works for a while.
    I think something either broke when I removed tray (unlikely) or it's not being properly seated. don't know.
Found someone that was not going to charge me money for advice.
Posted on Sep 23, 2008
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker
IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba ice maker not dispensing ice
this is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
No ice
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
324 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
