Question about E-Machines Computers & Internet
I have hooked my computer to the internet and I get and error that said I have no veiwing IP address
  • 32 Answers
U can contact your internet provider and they can step you through it , i had the same problem myself and they helped me through it step by step...good luck
Posted on Sep 21, 2008
    Scholar:
  • 68 Answers
I think the problem is with the modem.....you have to configure the modem.....then it will work.....i am a software engineer and i have experience in it.....try this.....it will work 100%.....
How can i find the ip address
In Win7, right-click on the computer in your system tray at the bottom right corner of your screen. Left-click on " Open Network and Sharing Center" , then Left-Click on your connection under the 'Veiw your active networks' section. Then Left-click on the 'Details' button. Your ip address is next to 'IPv4 Address'
Apr 12, 2013 | Samsung Computers & Internet
Tip
Internet Connection Basics
Modern high-speed internet connections are made using DSL or cable modems. In general, most DSL modems also act as routers, but not too many cable modems act like a router.
Some internet connection basics: Every device connected to the internet has an IP (Internet Protocol) address. The address consists of 4 groups of up to 3 numbers each. They would look like this: 123.111.36.145 (0 is the smallest number and 255 is the largest you will see). When you connect to the internet, you are assigned an IP address by your ISP (Internet Service Provider). When you hook up your computer
to the modem, the signal is passed through the device to your computer and the device's IP address becomes your address. This is not secure, as the "bad guys" could type your IP address into their machine and theoretically see your computer and access all your data.
Connecting with your modem: Modems come with a CD nowadays. Running the setup CD makes connecting quite easy. With a DSL modem, you normally have to provide a username and password to log on. Cable modems generally rely on the cable connection to your house to recognize who you are and when you run the setup CD, you are automatically connected.
The router: The purpose of this device is twofold--one is to take the signal you get from your ISP and send it to a number of computers in your home network. The second purpose is to take the IP address and send it to a different address on each computer. This acts as a "firewall" in that the IP address assigned to your computer is no longer the address of the computer. Those bad guys trying to hack into your system will have a much more difficult time.
Types of routers: There are wired routers capable only of hooking up computers with ethernet cable within a network. There are wireless routers--normally these have 4 wired ports and a set of antennas. These function will in a mixed environment of wired and wireless computers. Most people these days are using wireless routers.
In my next tip, I'll describe how you go about hooking up your new router to an existing internet connection.
on Aug 09, 2010 | Computers & Internet
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
JN763. Access rejected from your IP address.
To resolve this problem, follow these steps.
  1. Using the Internet Service Manager (Microsoft Management Console), open the Internet Information Server (IIS) snap-in and select the Web site reporting the 403.6 error. Right-click the Web site, virtual directory, or file where the error is occurring. Click Properties to display the property sheet for that item.
  2. Select the appropriate Directory Security or File Security property page. Under IP Address and Domain Name Restrictions, click Edit.
  3. In the IP Address and Domain Name Restrictions dialog box, if the Denied Access option is selected, then add the IP address, network ID, or domain of the computer that requires access to the exceptions list.
    In the IP Address and Domain Name Restrictions dialog box, if the Granted Access option is selected, then remove the IP address, network ID, or domain of the computer that requires access to the exceptions list.
Jan 31, 2011 | Microsoft Computers & Internet
I have a D-link EBR-2310 router and hooked it up a couple days ago. Since i have hooked it up and put my home comp and laptop on it. It runs the internet for a while and then it throws up errors on my comp...
You probably have a static ip address set on one of the pc's. The router is set to give out ip addresses automatically. If one of the pc's has a static ip address set,(within the range of addresses that the router is dishing out) then the router may try to give out that address, see that it is already in use, and produce the error.
This is easy to fix:
For xp:
go to the control panel, then to network connections. Right click on your network connection, and left click on properties. In the white area of the window that pops up, click on 'internet protocol tcp/ip' and click properties.
For vista:
Go to the control panel, network and sharing centre, then click on manage network connections, right click on your network adapter, left click properties. Click on internet protocol version 4 (uncheck version 6 if it is checked) and check for auto ip and dns just like in xp.
Both pc's should be set to obtain an ip address and dns server automatically. If there are numbers in either area, this is the problem for sure. Make sure both are set to get an address automatically, reboot router and both pc's and that should be the end of it :)
Please post a comment and let me know how you make out.
Aug 23, 2009 | D-Link 4-Port Ethernet Broadband Router...
Jul 27, 2009 | Computers & Internet
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Nov 17, 2008 | Dynex 4-Port Ethernet Broadband Router...
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
