Question about Cameras
The eye lens on my digital camera won't close. I changed batteries and no luck. Camera turns on but just says 'lens error'
  • alongh0413 Sep 21, 2008
    Twisting the lens did the trick. Thanks so much!
    Twisting the lens worked! Thanks so much!
    Sergeant:
  • 399 Answers
Somthibg is blocking the lens to shut off.try cleaning any dust thats blocking the lens .also try to pull down the lens manually once so as to get the lens on its original position and then see whether it works properly.
fell fre for any futher queries and help.
thanks
Posted on Sep 21, 2008
    Genius:
  • 3,422 Answers
Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
  • Priya darshan Sep 21, 2008
    Thank you for using fixya and have a nice day:)
    Genius:
  • 1,847 Answers
Try resetting the camera to factory settings and then try.
  • Legin Varghese
    Legin Varghese Sep 21, 2008
    if that doesnt work
    The gears are either broke, worn out, or something has cause them to become misaligned.
Lens won't close
This problem happens because of long time no using/ Dust or Lens guide pin damaged. If the lens guide pin damage then there is no chance for repairing . Only solution is replacing the lens. For the solution you need to follow the steps. 1. Turn off the camera and remove the memory card and clean the external body of the camera and make sure in place of the lens there is no dust or damaged sign. 2. Now turn on the camera without memory card & make sure the battery are fully charged. 3. If the lens not moving then give a little shake or thrust by hand ( carefully very slow) and then wait for a moment. If no changes then turn on the camera and give a little twist an anti clock side and leave for few second. It is risky ( Do it slowly at your own risk) 4. If nothing change then reset the camera setting from the menu option. After following all steps, if the camera does not start working then you need to visit service center for replacing the Lens or Repairing. But before repairing ask service center the approx cost. if they told you to replacing the lens then do not do that. Because a new lens & service charge cost you near about a new camera price. So best is buy a new camera. If you have any more questions ask me I fell happy to answer your question. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html - - - Do it your self lens fix
Aug 09, 2012 | Nikon Coolpix S6100 Digital Camera
The eye of the lens won't close anymore and keep saying to turn the power on and off again, what should I do?
You might try removing the battery for a minute or two to reset the camera. You may lose any special settings in the process. After reinstalling the battery, try turning the power on and off again.
Apr 28, 2012 | Sony Cyber-Shot DSC-W570 Digital Camera
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
Sep 24, 2010 | Kodak EasyShare Z740 Digital Camera
My Sony DSC-W230 turns on and lens keep opening and closing, and then it shows "turn power off and on again". how do i fix this ?
This sounds like a stuck lens. Here is a good blog about things to try to fix it:
The blog is about a lens error, but when the camera lens opens and closes, there is often a problem with the lens.
Also make sure the battery is fully charged, and good. Also make sure the contacts are clean on the battery, and also inside the camera.
If all fails to get it working again, get an estimate on repair first, since the cost can justify just going ahead and buying a new camera.
Good luck, and hope this helps.
Aug 01, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Camera turns on, but does not take a photo lens does not close
Hello. First, make sure the battery is properly charged and/or there has been no battery leakage or other such damage inside the battery compartment. Next, since the lens won't close, the camera senses an error condition and is programmed to shut down. Has the camera been exposed to heat(hot car) or any kind of moisture? Check carefully for impact damage--if the lens is crooked or has become mis-aligned. Has the camera been to the beach recently? Blowing sand(which can be almost non-viewable to the human eye) is notorious for jamming electronic equipment such as camcorders or cameras. Barring any battery problem, the camera will most likely need to be seen by a qualified tech.---Rick
Oct 20, 2009 | Fuji Cameras
My PowerShot A650 IS...the lens opens and closes
try charging the batteries to full when using the camera, if that did not work, update the firmware from CANON.COM.
if that also did not work, you need to visit the service centre as it could be a CCD problem or a shifted lens.
Aug 21, 2009 | Canon PowerShot A630 Digital Camera
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
Will not stay on
Will the lens extend when turning on? , can you see any message on the LCD? it is possible there could be a system error or lens error (lens error if jammed all the way in closed position, usually makes the camera shut off right away)
Sep 02, 2008 | Nikon Coolpix L11 Digital Camera
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
