Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door closes 75% of the way and re-opens, light starts flashing.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you have a Chraftsman/Liftmaster:
Check to see if the door is running correctly.
Run the door down and pull the emergency release. See if the door will run easily by itself.
If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
If the door runs fine then check the up and  down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing  the garage door). Turn the light blue adjustment screw with the up (or down) arrow to a higher number.
If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Posted on Jan 07, 2009
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Lights flash on dishwasher but it won't turn on
maybe a problem with the sensor 'door open/door close' check if its dirty or stuck if mechanical. press door to close and hold tight close while starting to identify.- or no sufficient water supply- or used water cannot drain out
Jun 15, 2012 | Frigidaire Dishwashers
My chamberlain garage door will not close. I have checked it manually and it works fine. I have check the sensors and they are inline Please help
If when the door starts to close the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flashing. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Sep 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
What is the problem when I pressed a button on the remote to close the door but the door did not close and the light at the openner was flashing?
Anytime the main light flashes 10 times and the door starts to close and then reverses to the open position it is a door sensor problem. Make sure they are still pointed at one another and the small light on each one is lit and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster Model 1240. Door will open by remote or wall opener. The door will only close while holding wall opener button down. If i try and close via remote, light starts blinking and door...
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a sensor problem. Make sure the light on each sensor is on and not flickering ever so slightly. Make sure they are not moving when the door starts to close. Lights on sensors should not blink. One light should stay on constantly and the other sensors light should go off when you block the sensors.
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Both lights on our garage door sensors are green (not blinking), but the door will not close with the remote or button in the garage. It does close if you force it by holding down the button in the garage....
If the main light flashes 10 times when the door starts to close and then reverses it is a door sensor problem. Look very closely at the lights on the sensors. If one of them is flickering ever so slightly it will give you the problem you have.
If the main light is not flashing then you need to increase the down force which is near where all those white wires go. A 1/4 turn should do it.
Nov 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, with out hold down on button.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
Sep 06, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
102 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
