Question about Indesit 24 in. IDL500 Built-In Dishwasher
Indesit IDL530 Door lock broken on dishwasher indesit IDL530 how easy to replace ourselves
  • 75 Answers
It will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Posted on Aug 02, 2009
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl530 2nd and 4th lights flashing
rang indesit enginners there is a fault with the heating element needs to be replaced thankfully under guarantee only had it 8 weeks 13.08.09
Sep 23, 2008 | Indesit Dishwashers
The second two lights on my dishwasher are flashing and not working any help would be great IDL530
On my IDL40S the second two lights showed that the water was not getting through. Have you checked the supply?
Jul 20, 2008 | Indesit Dishwashers
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
Indesit d61 dishwasher
contact parts dept for unit. check on line. should be easy to get.
good luck
mark
Oct 28, 2007 | Indesit 24 in. D61 Free-standing...
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Indesit 24 in. IDL500 Built-In Dishwasher Logo
357 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
