Question about Panasonic DVD-LX9 Portable DVD Player
DVD LX9 problem
Watching a DVD on this unit, put on stop to grab a bite. Came back, pushed play. NADA. No screen, no sound, no spinning DVD. Battery indicator show it has charge, but we charged again. Indicator lights went from yellow (charging)
to red (when charge completed). Still no go. Any thoughts on problem? Is it worth repairing, or just junking it? Thanx in advance !
D & S
  • Anonymous Oct 08, 2008
    I have the same problem working just fine and then no power no action... once it goes from start to play no picture not even spinning the disc.
jackboy
  • 2985 Answers
SOURCE: Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Posted on Aug 29, 2007
zair
  • 82 Answers
SOURCE: dvd reading problem
The Spindle motor is defective, replace.
Posted on Feb 16, 2008
SOURCE: Panasonic DVD-LS80
I have the LS91 model and it tells you in the instructions what you need to do to get the extra time. Essentially you need to reduce the brightness to -5. This dulls the picture but if you are in a low lit room then it's no problem. To do this for this model you hit monitor mode twice and then reduce the brightness.
Cheers
Posted on May 29, 2008
BlackOnyx
  • 102 Answers
SOURCE: Error Message H07 - what is it?
The last time I opened up my Panasonic DVD-CV52, I looked at the little white bush on the motor spindle, it has a small spring which presses against the side of the bush. I can see no purpose for this spring/bush other than to provide some drag to the motor. Anyway, I removed the spring, so that the bush would no longer drag against the shaft, that was a few years back, and I haven't had a problem since. Of course a temporary solution is to oil the bush!
The www.ledcar.com/pdvdh07/ link mentioned above provides an excellent pictorial guide to disassemble and reassemble the player.
Posted on Aug 06, 2008
  • 92 Answers
SOURCE: my computer battery light is blinking red during charging
it means that the battery is bad
replace battery
Posted on Apr 11, 2009
The buttons on my Panasonic DVD-LX9 will not work
a little more detail needed.
do you have a picture/sound?
is the powerlight flashing quickly or slowly ?
disc spinning?
need more info to help.
Dec 29, 2009 | Panasonic DVD-LX9 Portable DVD Player
Disney C1320PTVD TV/DVD Combi. Won't play discs just makes a spinning sound!?
You have to replace the DVD player. The problem is that parts are not available and it's difficult to open the unit. There are about 20 screws to remove, including four screws hidden behind each fender. You have to pry the fenders and rip them off to break two brackets that hold each fender on. The fenders still hold on fine with the remaining seven tabs on each fender. You have to eject the disc to get the mouth off.
I have a working DVD player for sale. It's from a car TV with a defective picture circuit, but the player runs and I hear the movie soundtrack, so I'm 99% sure it's good. I broke the mouth off the player, but it could be glued back.
If you have a good motherboard for sale with a bad DVD player, I might buy the motherboard from you.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Oct 13, 2008 | Disney DTD1363-CAR 13" TV/DVD
Screen got really hot and now it won't play DVD's
I was going to see if you DVD player has a reset button on it but it isn't popping up on Audiovox website.
If you open up the player see if there is a reset button on it. Hold it down for about 5 seconds and see if that works.
Unplug power from the unit and remove the battery as well. Put them back in.
Try a different DVD in case its warped or damaged.
If those don't resolve the issue you should take it in and have someone look at it.
Jun 17, 2008 | Audiovox DT102A
HO2 Error???
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Apr 14, 2008 | Panasonic DVD-RP56 DVD Player
H02
This weekend we were watching a movie. It started to skip. I thought it was a dirty disk, took it out, cleaned it with a dry cloth and put it back. Now nothing will play.
When I insert a disk it starts to revolve the machine says reading, two zeros appear and the it stops. My wife noted a message H02 and the manual says to call for an explanation.
We tried turning the machine off and on and we tried pulling the plug -- no luck. What is the problem?? Jeff
Apr 06, 2008 | Panasonic DVD-RP56 DVD Player
Dvd panasonic ls91
http://www.fixya.com/support/t284940-panasonic_dvd_rv26_problem_h02
Maybe you should return it if you can.
Nov 22, 2007 | Panasonic DVD-LX9 Portable DVD Player
Unit not responding
Not the solution but it has been suggested to remove and replace the CMOS battery. Can anyone help me finding the CMOS battery on an LG RHT387H
Sep 27, 2007 | LG Electronics LRM-519 Digital Media...
After trying to read a disc it says cannot read
I had the exact same problem - I bought this DVD player TODAY at a garage sale for 5 bucks, they said it wouldn't read the disc, so I looked it up and found this thread. I did what that other person did, in that I had a DVD loaded into the player, then I took the top off. The DVD worked perfectly! I actually didn't even have to touch anything inside. I then put the top back on, making sure not to tighten the screws too hard. I think what it was is that this is a very slim unit, and there really isn't much room for the motor to spin the DVD, especially if there is even a 1 millimeter bend in the casing - it prevents the DVD from spinning around. I would reccomend never putting anything on top of this DVD player.
Jan 14, 2007 | Sony DVP-NS501P Progressive Scan DVD...
Samsung dvd-v4600
sounds like you need to clean the laser lens. Try using a disc cleaner first and if that dosent work then take aprt and find the laser lens, take a clean q-tip and put a little alcohol and swab the lens very carefully Good luck
May 09, 2006 | Samsung DVD-V4600 DVD Player/VCR
Panasonic DVD-LX9 Portable DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
