No power JVC would not turn off either with the remote or on the switch on the TV. Unplugged it and now it will not turn on JVC AV 32980
Replaced the C226 capacitor. Using advice from this web site, found the capacitor, and yes it looked burnt, went to Radio shack and for $1.69 bought a new one, put it in, and we were all set. Does have to be soldered in, in all it took us about 1 1/2 hours. Thanks for the tip.
Posted on Sep 22, 2008
Fuckin jvc tv will not turn on and its really
Try to unplugged to the power outlet for 2 minutes, and then power on. Or for the meantime if it have protection circuit like surge protector disconnect that for the meantime. And then power it on.
If not there's maybe a high voltage circuitry problem if this is a crt type tv.
Apr 30, 2009 | JVC AV-27D502 27" TV
LOOKING FOR OPERATORS MANUAL FOR MODEL AV-32890
http://www.retrevo.com/s/JVC-AV-32D302-TVs-review-manual/id/279ag311/t/1-2/ - 65k -
Feb 13, 2009 | JVC AV-32D305 32" TV
Tv turns on and off
My JVC 35 " AV 35750 toggled on/off non-stop too.
Fix for me: Unplug TV. Trace cables from on/off switch to main circuit board. I unplugged the cable at that point to eliminate the the on/off button and remote control sensor. Applied power to the TV and my TV stopped cycling on/off so I figured the problem was probably not on the main circuit board but with the push button/ remote control sensor board. I again removed power from the TV and plugged the cable back in to the main circuit board. I then applied power back to my TV to verify my symptom, but when I did this, the TV worked fine again.
Many times resetting circuit board connectors will clear electrical problems.
Jul 22, 2008 | Televison & Video
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
JVC AV-48WP30 48 in. Rear... Problem:
Take the batteries out of the remote control. Press every button 2 times. Then re-insert the batteries. While doing this unplug the TV and hold the power button down for 30 seconds. Then let go and leave the TV unplugged for 3 min. Then turn tv on do a channel scan and then try yhe remote.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
No power
That day while you were out it might have rained or lost total power in the house and your TV might have suffer what is call power surge or lighting damage ,those two thing do a lot of damage to any electronic equipment,you need to get a qualified service technician to diagnose the problem.Sometimes there is no reason and the tv's just fail.Good luck.
Sep 18, 2006 | JVC AV-32980 32" TV
On Timer light flashing on my TV
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Nov 30, 2005 | JVC AV-27120 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
