Question about Toshiba Satellite M35X-S109 Notebook
Atheros 5001 Mini pci lan adapter
Is this a wireless adapter? I am going out to buy a router and I need to know if I need to buy a usb Wireless adapter or a pci cardslot adapter to access my new home wireless network. Thanks, cheffer
  • Toshiba Master
  • 4,338 Answers
If it is a LAN adapter, It is not a router.
A router enables you to connect several computers(256) with DHCP IPs
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Sep 28, 2008
SOURCE:
I want PCI DL1008A Lan Driver
http://download.cnet.com/802-11b-g-atheros/3000-2112_4-162108.html
http://download.cnet.com/wireless-lan-atheros-wireless/3000-2112_4-167591.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: ethernet driver
you might have to try a few times to get it right
hope it helps
Jul 04, 2012 | D-Link DFE-530TX+ Ethernet ED100W Network...
Windows 7 Atheros network adapter will not connect to WRT54GS Linksys Router
First, use a lan calble to reach the router. Then check the settings on the router and see what ip address is assigned to your laptop. Also check the password setting on the router. Try using WPS as an alternative to setting up the password, etc. WPS will work with either a pin number or push button. It should solve your problem. If not, then use the first solution, although it may be a little more complicated for you. Last thing you can do is go to into Microsoft's network and sharing center, and choose "manage wireless networks" and make sure the adapter is "enabled".
Jun 23, 2017 | Cisco Linksys WRT54GS2 Wireless-G...
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
Atheros AR500EG wireless Network adapter tired
Well those are actually PCI cards. You can have the wifi card replaced or buy a USB WIFI adapter as that would be cheaper.
Aug 16, 2010 | Toshiba Computers & Internet
USB MINI WIRELESS ADAPTER PASSKEY
right Click on the wireless network connection
go to properties.
Under the wireless folder.
go to advanced.
Click on computer to computer adhoc networks only.
It should work then.
I am assuming you have wifi on your desktop.
Best case go out and buy a wireless router. It will be more secure.
Jun 30, 2009 | Adapters.com USB Wireless Mini LAN Adapter...
Device not Recognized in Xp+Sp3
you are better off getting a refund and buying a PCI wireless card and installing that instead ( linksys or netgear or something along those lines )
May 09, 2009 | Adapters.com USB Wireless Mini LAN Adapter...
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Toshiba Satellite M35X-S109 Notebook Logo
515 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
