Question about Kodak EasyShare C533 Digital Camera
I cudnt connect my camera with my computer
I couldn't connect my camera with my computer, may com says " USB IS NOT RECOGNIZED " but the other hardware is working properly.. plz help me...
Get's on but will not download the photo;s u have c533 kodak
Posted on Oct 09, 2008
Programa no responde
If I understand your problem right, the installed Olympus program does not launch (start) when connecting the camera to the computer using the Olympus' USB cable.
1. For the program to start automatically, the camera must correctly being recognized by the computer. Check if this is the case! When connecting the camera to the computer, you should see information shown on the camera's display!
2. If not, try to connect the camera on another USB port, or better another computer to diagnose the problem.
3. If the camera is recognized, you can set an option in the program to autostart the program when connecting the camera to the computer.
4. If it does not help, reinstall the program.
May 27, 2011 | Olympus SP800UZ Digital Camera
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
After conecting to my computer there is no recocnition of camera on computer, time and date were added before conecting to computer will this make a difference to conection does this affect the internal...
Setting the Date and Time manually does not influence the behaviour of the camera. However, if the camera is not 'recognized' by the computer: Check if the USB cable is properly fitted in the camera. Put the other end in a different computer USB port. The computer should see the camera as a Removeable USB Device. If the problem persists, connect the camera to another computer and see if it is recognized.
Jan 18, 2011 | Olympus SP800UZ Digital Camera
My sony cybershot T2 is no longer recognized by any computer I connect it to via USB. But when I connect my sister's camera (also a T2), it works fine? please help
You may have a bad USB in your camera connector in your camera. Any repair shop should be able to repair for less than $50.00. Also check that you do not have a bad cable. You may also want to try on a different computer than yours. if it works you may have a driver or USB conflict with your computer.
Jul 02, 2009 | Sony Cybershot DSC-T200 Digital Camera
Usb not recognized
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 05, 2009 | Casio Exilim Card EX-S100 Digital Camera
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Samsung s630
First, I need to ask the dumb questions:
1. Are both computers running XP?
2. When you connect the camera, do you turn the camera on?
3. Do other USB devices work when connected to the same
USB PORTS you are using to connect the camera?
Ok, since the camera is not recognized at all on both computers, we can pretty much disregard USB PORT failure, but just in case, try different USB PORTS on both, please.
Most if not all cameras should be recognized as mass storage devices just by connecting them to USB PORT on computer, and should be visible as a new drive in MY COMPUTER icon.
Maybe your bundled USB CABLE is not working, or this is one camera that insists on using the bunbled software package that came with the camera.
Last thing to try is to buy a multi-card reader/writer and put the memory card in there. That has to work!
Hope that helps.
Dec 30, 2008 | Samsung Digimax S630 Digital Camera
1st, try using another USB port. Some ports are only able to recognize something like a mouse, or speakers. 2nd, make sure that when you connect your camera to the USB cord, that your camera is off. Then, once connected, turn the camera on to 'AUTO'. This will force your computer to find a way to review the media on the device. It will do one of three things. It will open your Kodak Easyshare program, ask you what you would like to use to open the media (choose either your existing software or open with your computer's media software) or it will open a new page and show two or three folders with your photos inside.
Hope it helps!
Oct 18, 2008 | Kodak EasyShare C613 Digital Camera
Usb cord not recognized...?
Jul 22, 2008 | Fuji FinePix A330 Digital Camera
Kodak EasyShare C533 Digital Camera Logo
57 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
