I try to make my toshiba external hard drive back up my files from my pc but i don't know how to do it?
  • 781 Answers
There are different things you may want to try..
if backup is what you need and not just a copy of your files you can use and backup utility that comes with windows xp pro (I'm assuming that's the os your using). to look for the backup utility go to ; start>all programs>accessories>system tools>backup, it will usually open in wizard mode so follow the instructions.. basically what you will be doing is determining what needs to be back up, where you want that backed up (select the externa hdd unit that should be avaliable if you have your external hdd connected) and when you want to start back up... read through the prompts... it should be fairly easy.
if you don't have the backup utility (you may be using home xp edition)... you may need to get a windows xp cd and follow this instructions to install it as described here:
http://www.microsoft.com/windowsxp/using/setup/maintain/backupsw.mspx
Posted on Sep 21, 2008
Our computer died. I had backed up to Toshiba 1TB external hard drive using NTI backup now EZ. Trying to restore pics, programs etc to new computer. Getting error that says it can not find on on external...
You have an issue - if my understanding is correct ' you are trying to restore your files, programs etc., to a new computer.
Backups are meant to restore the files and windows operating system etc. on the same computer the backup was created from. If you bought a new computer, it cannot do any restoration of the backup file from the hard drive.
if this is not the case, you need to provide more information for anyone to help.
Aug 03, 2014 | Toshiba Computers & Internet
How can I find the files on my 1tb, seagate external drive?
You maybe removed the driver for the hard drive when you ran the anti virus. Those programs can do some strange things. If you click on the start, then computer. It will show all hard drives on your system. If you cannot find your files. I would think your computer does not see the external hard drive. To reinstall the driver, you would need to go to the driver's manufactures web site to down load or yours may have came with a disk. If so just run the disk. Could do a system restore , but that would be last option .
Aug 02, 2014 | Seagate FreeAgent Pro 1TB External USB...
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I don't know how to download my files to the Iomega 500gb portable hard drive. Then, if I want to bring back my files, how do I do that? I sound like an idiot. I've had this thing for about 6...
When you plug the drive into the computer does windows alert you that a new device was detected? If you open my computer you should see and hard drive listed that will only be there when your external drive is connected.
Aug 21, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
I get the error message when i try to create media recovery for my laptop toshiba l505. the error messsage is "no HDD recovery area", "the toshiba recovery media creator cannot be...
I am glad to HELP YOU!
When you start to create the RECOVERY MEDIA your machine is creating a virtual file [a temporary one...] that includes all parameters and drivers and system files of your operating system; once the temporary file is done the recovery files are written on the indicated media [a hard drive or a DVD/CD].
Because of the huge size of the file [the temporary one] you need enough room for the virtual file to be created.
So you got your error message just because you DON'T HAVE ENOUGH ROOM on your hard drive.
My suggestion is: find an external drive [a USB attached hard drive] and make the RECOVERY MEDIA there. Meanwhile try to clean up a little bit your hard drive by using that application in Windows called DISK CLEANER [START > ALL PROGRAMS > ACCESSORIES > DISK TOOLS > DISK CLEANER].
My best regards!
... and don't forget to RATE, please...
Apr 19, 2011 | Toshiba Satellite L305-S5907 Laptop
Formatting an external hard drive
Open up Folder Options\View\Show Hidden Files and Folders. Return to your Toshiba HDD. Do you see an hidden files? If so, try to delete them. You may have to change the Properties of these Folders\Files in order to delete them. BE WARNED, removing or deleting any folders or files that Toshiba placed in there could have negative affects on the way your external HDD runs.
Mar 18, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Computers & Internet Logo
David Payne
David Payne
