Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Error 1203 i own two of these printers and they both say the same thing. i have new ink in them
  • 4,041 Answers
Ok would you like try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
rasadam
  • 5 Answers
SOURCE: x4270 lexmark all-in-one InkJet Printer
Error 1203 is a bit of a generic cartridge issue. If this is a new printer and these are new cartridges, the most likely cause is defective cartridges, they do happen from time to time with new printers. It is also possible that there's a communication issue in the cartridge bay in your printer. Personally, I wouldn't try to do these diagnosing steps (Short of checking for any obvious mistakes). Since this printer is brand new, I would put it back in the box and return it for an immediate replacement. Some retailers would try to find any way to discredit your return right, the aim would be to give them as little ammunition as possible. To try and self troubleshoot the cartridge, first make sure they are inserted correctly. First, ensure you removed the tape from the contacts on the cartridge from its package. Make sure when you snap the cartridge in, it doesn't appear loose or easy to shake in the cradle. If you're still getting the error, remove the cartridge and check for any residual ink. If ink is present (appearing to leak in any form), it's possible this is causing the error. You can try cleaning the cartridge, a safe solution to use would be a light application of methylated spirits on a cloth that doesn't disintegrate. Holding the cartridge at its sides, you can run the cartridge in a vertical motion on the cloth. Horizontal motions can potentially damage the cartridge. You can also check the contacts on the printer (This is, the gold circuits where the cartridge touches the printer in the cradle). If ink appears on this, this can also be causing the issue. You would need to use an electrical safe contact cleaner (A very light amount) and a safe cloth to clean it with. Anything that can leave particles would be unsafe to use. Make sure to let the solution dry before reinserting the cartridge. Hope everything works out.
Posted on Jan 24, 2007
SOURCE: Error #1203
Call your lawyer and suggest a class action law suite. IT"S A KNOWN ISSUE!!!
Posted on Dec 24, 2007
JackHeath
  • 1049 Answers
SOURCE: Dell 942 Error 1203
Error 1203 occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
Posted on Jul 28, 2008
d2704
  • 101 Answers
SOURCE: Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Posted on Mar 07, 2009
  • 684 Answers
SOURCE: dell 946 error 1203
In this Case just unplug the Power Supply from the Printer...........
Remove both the catridges from the Printer........
Move the Catridge carrier which holds the catridge back and forth for abt 20 times as fast as u can....
Now Turn the Printer On it will work fine.........
Good Luck...........
Posted on Apr 05, 2009
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
Lexmark x4270- Can't find manual. Shows error 1203. How can I correct this. Thanks
Hi
Error 1203 occurs due to smearing of ink on the carriage bottom where the cartridge head touches the carriage bottom. Please turn off your printer and unplug it.
Clean the bottom of carriage with a damp cloth and clean any dried ink. Make sure that you use the printer after 5-10 mins or until the carriage area dries up completely.
If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
Now try and check whether you are still getting an error. I hope that you are using orignal Lexmark ink. If not then please use genuine inks only.
Daniel Scott
Jun 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Dell all in one printer 964... Error message 1203... What does this mean? I recently had the ink refilled at Walmart. The printer did work after the ink was refilled, but now it's being very odd and will...
Hi there
or
All the best Pineworks
Apr 27, 2010 | Dell 966 All-In-One InkJet Printer
Just got new ink-got error #1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Jan 21, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have inserted a new color ink cartridge, but when i close the printer I get an error message that reads 'Cartridge Error, Error #1203'. I have tried two different cartridges with no success. What is...
Yes ok it will be the inks.
or
Jan 05, 2010 | Dell 966 All-In-One InkJet Printer
Just installed 2 new new ink cartridges now it shows error 1203 HELP
Try following these troubleshooting instructions from Lexmark.
Error 1203 Troubleshooting
Thanks for using Fixya. Hope this helps.
Sep 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
Error # 1203 Cartridge Error
Have you recently refilled or replaced any of the cartridges. 1203 is usually one of two things.
1. An overfilled cartridge (fixed by wrapping in damp paper towel for a bit until excess ink wicks out)
2. Ink smeared on contacts (fixed by cleaning contacts on cartridge and on printer's cartridge housing)
Aug 05, 2009 | Lexmark X7350 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
