Question about Minn Kota Maxxum 80 Freshwater Bow Mount Trolling Motor With Hand Contols And Maximizer
MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
I HAVE A MINN KOTA MAXXUM 80lb TRUST BOW MOUNT. I WILL BE GOING ALONG OK , WHEN IT WILL CUT OFF. I CAN TURN THE MOM/CON SWITCH FROM MOM TO CON, AND BUMP THE FOOT PEDAL HARD. THIS WILL START THE MOTOR AGAIN. I CAN THEN SWITCH BACK TO MOM AND IT WILL RUN UNTIL IT DECIDES TO CUT OFF AGAIN. I NEED TO KNOW WHAT PART I NEED TO ORDER TO FIX THIS PROBLEM. THANKS DOUG
  • WJSTUART Sep 21, 2008
    I WILL CHECK THIS PROBLEM AND THINK THIS IS VERY HELPFUL
  • Anonymous Mar 12, 2014
    I have maxxum 65 minn kota the directonal arrow lighs up but motor does not work charged batteries it work a couple of time now quit again. could it be batteries
Hi
I have the same problem as doug...what soled this problem?
Posted on Mar 08, 2009
    President:
  • 1,952 Answers
Minn Kota’s larger brushes, windings and commutators generate less heat, less noise and run cooler…extending motor life and conserving battery power. You get greater sustained thrust and more time on the water. A unique bearing system produces low rpms/high torque to cut down on fish-spooking noise — so quiet they’ll never hear you coming.
Posted on Sep 21, 2008
    Brigadier General:
  • 5,158 Answers
Any relays on that unit that you can see... likely needs to be replaced.
Robert
    Genius:
  • 2,920 Answers
It has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
The trolling motor will just quit sometimes if I shake the handle several times it will start back up
sounds like a loose or bad connection on the throttle switch will need to open the control tiller and check connections if you have a meter ohm out the wires at the connector and switch to make sure all connections are good this is a bit involved and I recommend doing on a bench not in the boat If you need more detail just ask You know this sucker comes with a 2 year warranty right !
Apr 18, 2016 | Minn Kota Maxxum 80/BG/Hand Freshwater...
Can i convert my bow mounted mini kota 40 to a transom mount?
No you cannot. Due to the hard mounted foot controls, it has to stay a bow mount.
Oct 18, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Can you wire a minn kota foot control
.....I think so ;)
Here's a schematic, complete with wiring diagram:
Maxxum 70 Bowmount
Best of luck!
Mike
Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Mar 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota Maxxum 80 Freshwater Bow Mount Trolling Motor With Hand Contols And Maximizer Logo
1,347 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
