Xerox 416 Work Centre Pro Paper Jam
Paper Jam occurs in different areas of the copier. Can you recommend an easy fix for this? Is there lubricant that needs to be applied on rollers or is there another problem? Using 20lb office depot brand copy paper. Also tried Xerox Brand 24 lb copy paper.
Thank you.
  • yia2008 Sep 23, 2008
    Thank you. Can you tell me where to purchase a power pack for the 416 Pro? Thanks again for the help.
    The copier appears to be in good physical condition. I purchased it used. So I'm not sure of the age of it. It has 89,000 copies on it.
    It paper jams often, but will sometimes make 5 or so copies before it jams. it appears to be jamming mostly at the exit point, but sometimes will jam near the enter point from the paper tray (more regularly at the exit point of the copy process.
    Hope this helps you determine the problem. Please let me know if you need additional information.
    Thank you.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Sorry i was having downtime with my cpu before now .
for your paper jam, check your copier manual for reomended paper grammmage prescribe by xerox.
entring tray jamming,use a damp towel to clean the picking rubber or roller inside the tray & use blower to blow dust out of the entrance sensor.
exit jamming, check the fuser unit of smooth runniing during machine warmup.check if there is any ink stuck on the rollers .then check the sepration fingers on the roller if there is any stuck spring.
but if your maching is jamming without any specific position,check your input & output voltage of your power pack for possible voltage drop. moreso you have to make sure that your machine is place on a level table.
thanks.
Posted on Sep 29, 2008
  • 790 Answers
Hi
try first cleaning you rollers put a lubricant in the rollers primary and secondary and to feeding rollers then test run!
Thanks!
Posted on Sep 23, 2008
    Genius:
  • 1,550 Answers
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
  • SAM ANDERSON Sep 23, 2008
    Sorry for responding late .
    As you said you have problem at
    entry level sheet stops before entering the rolls more likely to be
    dirty entry , drive problem or sensor problem.
    Running sheets with dark lead edge can cause sheets to stick to
    rollers,try running blank sheets to clean up, if they get through then try
    normal copies
    If it doesnot work .
    Rebuild fuser and clean out recycling pump and hoses.
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
Oct 13, 2010 | Computers & Internet
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
What does code J1 mean on a xerox work center pro?
J1 mean any paper jam in paper feed area or sensor displace.lower cassate or multi pass tray.clear jam paper then solve your problem.
Dec 23, 2009 | Xerox WorkCentre M-24 Color Copier
My workcentre Pro 416 shows a jam, i have removed all jams that i could see. However it shows clear jam, and has 19 to dos on the screen, like open door, clean jam, close door, etc.. Is there a major reset...
On this 416 machine, there is one place you cannot see a jam.
Looking at the machine the right side doors need to be opened.
The lower trays feed paper and need to go up the by pass feeder area.
Just lower and behind the by-pass feeder the paper can get stuck, and you cannot see it.
If you try to push a card stock up from the bottom, the paper can be pushed out.
The other area is at the fuser. If the switch is worn it will not drop back into position. The tip of the switch wears and breaks off.
It is rare a sensor goes out on this machine, besides the fuser sensor. Each paper feed head needs to be checked to see if the paper sensors are bad.
Not seeing the machine, call Xerox for service repair if not resolved.
Jul 15, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Manual
Google a bbusiness called " the parts drop" Give Britt a call, he probably will have one.
Jul 10, 2009 | Xerox WorkCentre PRO 128 Copier
Copier says paper jam in area 2, no jam
What is the model number of the copier? That would help a lot in knowing what to tell you. The paper feeders are all different. but I suspect bad rollers or sleeves.
Mar 19, 2009 | Xerox Office Equipment & Supplies
Xerox 416 Pro Copier Paper Jamming
As you said you have problem at entry level sheet stops before entering the rolls more likely to be dirty entry , drive problem or sensor problem.
Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get through then try normal copies
Sep 23, 2008 | Office Equipment & Supplies
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
114 people viewed this question
k24674
