MY DVD DRIVE DOES NOT WORK THE COMPUTER SAYS NO SUPPORT DRIVE CAN YOU HELP
  • 781 Answers
We may need more details
1. did it ever work or you just installed it?
2. where do you get the no support drive message? after clicking what?? after doing what? in what program?
3. find out if your computer actually sees the dvd rom drive being detected.. go into start>righ click my computer>properties>hardware tab>device manager and look into cd/dvd rom drives ... do you see your dvd rom drive there?
Posted on Sep 21, 2008
Computer does not recognize there is a disc in the DVD drive
If this is a Windows computer. Make sure that you have the proper drivers installed.
Is the disc scratched? that could also be an issue.
Feb 28, 2011 | Computers & Internet
My dvd drive does not appear anywhere. Its not in device manager, the registry thing don't work and microsoft is no help at all. Please help.
Sorry. Not enough information.
The DVD drive must be recognized in Boot up before you can use it. Check your owner's manual or have a knowledgeable friend help.
Chances are, a new DVD drive will be needed. They are very easy to change on a desktop computer.
I need:
Your make and model for the computer
Is it a laptop?
Does the DVD drive door open?
What operating system? Xp, Vista or Windows 7
Has the DVD ever worked?
Did you install a program and the drive disappeared?
Do you use bit torrent or limewire?
Do you have a driver disc for the DVD Drive or computer?
Mar 29, 2010 | Computers & Internet
Computer not recognizing Dvd drive
Hi, Check the MS word / software file it works DVD drive, if it recognize there is no problem the drive and play CD - format files.
If not recognize, i found that DVD Lens not working what you can do DVD lens cleaner disc you found stores. Rgds, Manju
Jan 26, 2010 | Computers & Internet
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
My compaq presarios dvd drive is messed up, it freezes dvd movies ive recorded on it. is there a fix? it records cds fine but has problems only recording movies. also sometimes when i put a disc in, the...
Hi brianlcrensh
It sound like you DVD drive is gone :O(
First bee sure that the DVD´s recorded are working normal in another DVD ex at your work. IF yes, then I could bee 2 solutions :
1. you have to less RAM and the processor is a old one and maybe you need to upgrade your machine.
2. your DVD drive is not working. The DVD drive and CD drive are running separately and that means you could still use this drive as a CD drive.
IF the drive is NEW you have the possibility to return it to the store and get a new one without costs.
Normally strange sounds on DVD drives means that the drive is damaged !! Today normally you can get a DVD drive for around 40 $ so making to much Trouble shooting and that drive could make many hours go for only 40 $. My last DVD drive did also make strange sounds and I did chance and now it is working fine.
TO CHANCE THE DVD DRIVE JUST OPEN THE COMPUTER AND REPLACE THE NEW DVD DRIVE IN IT (MAKE SURE THAT THE DVD DRIVE ARE MASTER OR SLAVE, LIKE YOUR OTHER DRIVE) OPEN THE COMPUTER AND IF IT TELLS YOU YOU HAVE A NEW CONFIGURATION THEN PRESS ACCEPT/SAVE TO C-MOS. WAIT A FEW SECONDS WHEN THE COMPUTER IS IN WINDOWS (IT TELLS YOU THAT THE WINDOWS HAS FIND NEW HARDWARE AND AFTER FEW SECONDS IT TELLS YOU THAT THE HARDWARE IS INSTALLED) AND NOW YOU SHOULD HAVE THE POSSIBILITY TO USE IT
here is a video to see how to do chance a dvd drive :
http://www.videojug.com/film/how-to-install-or-change-my-computers-optical-drive
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Compaq Computers & Internet
Hello my Dell Studio 1435, it can read CD but not reading DVD... it give noise when i put DVD..
Try using a good quality DVD cleaner first. The lens for cd/dvd are different so one may work if the other is dirty. If cleaning does not work then the dvd lens may be out of alignment or broke. With today's prices it is cheaper to replace the drive $30-40 than try to repair it. Hope this helps.
Sep 11, 2009 | Dell Studio 15 Laptop
My computer's dvd drive doesn't work, it can play cds and it can burn disks but it can't play dvds. ...
hi im josh in cebu phils.may i help you? if your dvd drive does't work with dvd inputs. try to check the following first be sure to clean your dvd drive coz dust may cover the lens inside that would make the drive wont work. 2nd if you are using different OS be sure to install dvd drive software such as power dvd etc. and lastly be sure you entered clean and clear dvd inputs. thats all hope i helped you.good luck
Feb 26, 2009 | Toshiba Satellite A135-S4527 Notebook
DVD drive doesn't work
It's likely that you have a bad drive. Before rushing out to buy another one, remove the device for CD/DVD drive under Device Manager and restart the computer. Let Windows reinstall the driver and see if that helps.
Additionally, you might want to completely remove the drive, check the connections on the end, and also use compressed air to blow out inside where the connection is made.
If after all that, still not working ...bad drive :(
Sep 28, 2008 | Acer Aspire 3502WLCi Notebook
Laptop DVD /RW Drive
did you try a dvd cleaner some times the laser inside gets dirty and then it will not work if this does not work try a different dvd player in it a little serect is to try a different one always if still does not work might have to redownload the drivers for your computer on your computers website ..
Jul 14, 2008 | Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
David Payne
David Payne
