Question about Garden
Craftsman mower 917 273201
Engine cuts off when you let the clutch out!
also the battery does not always charge!
  • 49 Answers
Check the seat switch for the running problem. Disconnect the switch and jump the harness with a piece of wire, and see if the tractor stays running. If so, then the switch is bad. As for the charging problem. Test the voltage regulator. Start the tractor and put a volt meter across the battery. Red to red and black to black. Run the RPM to full throttle. You should have a reading of 14 to 14.5 volts. If not, the regulator is bad. Hope this helps.
Posted on Feb 11, 2009
Craftsman riding mower back wheels not rolling, seem locked up, engine won't start. Clutch and levers still move freely. Was running fine last use. Not sure what is causing this
Grass always gets caught in mowers. THis may help.
Turn mower off, detach battery.
Turn mower on side.
Clean grass everywhere you can clean grass.
Right side mower.
Attach battery.
Start.
Does that help?
Jun 28, 2017 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman kohler magnum 18hp lawn mower
Hi there, I do not know the Craftsman mowers, but have experienced same problem with other makes. Suggest that you try the following, in this order. 1. Check that battery has water above top of plates. 2. Check that battery is well charged. Turn headlights on full and crank motor. If lights go VERY low then battery either needs charged from external mains charger or is defunct. Place large mirror in front to view lights during test. 3. Test that engine charging system is recharging battery during use. If battery is very low some systems will still start motor, but charger will not work. [Normally when this happens the dash charging light will show. Orange.]
The problem can be that as the electric clutch requires a lot of power to initiate the drive and a considerable load while running, if the battery is too low the engine generator cannot carry the load and so the system drops out. This may also stop the engine.
Oct 08, 2014 | Garden
Poulan riding mower will run but when i egauge the blades the engine will die
Check you battery for water above top of plates. Also check that the battery is not flat by charging overnight with external charger on mains. Be very careful not to touch clamps on to any part of the machine frame as this can do great damage or start a fire. Some charging units on mower engines will not produce enough power to charge a very flat battery and drive the electric clutch which requires a considerable amount of power to stay engaged.
Sep 28, 2014 | Craftsman Garden
Sears Craftsman mower 17hp Briggs & Stratton engine. Replaced starter, spark plug and fuel filter. Will not turn over unless jump started. When running has no power.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Aug 03, 2013 | Craftsman Garden
How can I test a riding mower regulator? (puts out 23 amps @ 3800 rpms. My dmm only goes up to 10 amps.(system won't charge battery while in operation. Can it be tested off the mower? Mower is a Craftsman...
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Jul 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman mower
charge the battery sometimes they come not fully charged if not push down clutch/parking brake sit on seat becouse of dead man switch and then crank it over
Aug 27, 2008 | Craftsman Garden
Garden Logo
510 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
