Question about PNY Computers & Internet
Installation cd will not load properly. It shows the background and the selection boxes but not the writing. I am trying to register my product. I select the proper box and the demoshield box displays for a moment and then it disappears. It displays properly on my test computer. I had to uninstall quicktime to get past the demoshield errors at the start.
    Brigadier General:
  • 5,158 Answers
Go right to their website and download the appropriate driver/software and install it from your computer instead of the cd. incidentally, remove the cd from the drive and inspect the working side... the shiny side and see if it has any smudges or scratches. the cd player may not be able to read it.
it's not mentioned but is that a pc or mac and what operating system are you using ?
Robert
Posted on Sep 21, 2008
How can i have hp psc 1510 driver and valid Win32
Here's the fix:
* First uninstall your current HP installation.*
Step one: Uninstall the printer driver and software
1.
Disconnect the universal serial bus (USB) cable from the computer.
2.
Insert the printer software CD into the computer.
3.
A prompt to uninstall the software displays. Follow the on-screen instructions to uninstall the software.
4.
Restart the computer.
Step two: Turn off the Terminate and Stay Resident (TSR) programs and other background programs
When the computer is turned on, a software group called the Terminate and Stay Resident (TSR) programs automatically loads. These programs activate some of the computer utilities such as the anti-virus software but are not required for the computer to function. Occasionally, TSRs prevent the printer software from loading so that it does not install properly.
In Microsoft Windows 98, Windows ME, and Windows XP, use the MSCONFIG utility to prevent TSR programs and services from starting up.
1. Click Start and then click Run. The Run window opens.
2. In the Open: box, type msconfig, and then click OK. The MSCONFIG utility window opens.
3. Click the General tab.
4. Select Selective Startup.
5. If there is a check mark next to Load Startup items, click the check mark to remove it.
6. For Windows XP systems only - Click the Services tab and place a check mark in the Hide All Microsoft Services box. Select Disable All.
7. Click Apply and then click Close.
8. Click Restart to restart the computer.
Unplug your USB printer cable and reinstall. That's it!
Visit the HP Help Documentation Page for this error.
Here's the text from their page in case the URL for this changes:
Issue
The printer software installation stops and the Printer Driver Unknown error message displays on the computer. This document applies only to products connected with a USB cable.
Figure 1: Printer Driver Unknown error message
Solution: Follow the steps below to resolve this issue.
NOTE: These instructions do not apply to Windows 2000 because the MSCONFIG utility used in Step two does not exist in Windows 2000.
1.
2.
3.
4.
NOTE: This step does not apply to Windows 2000 because the MSCONFIG utility does not exist in Windows 2000.
1.
2.
3.
4.
5.
6.
7.
8.
Step three: Install the product software
Listed below are several options for installing the product software. If the product software CD is not available, HP recommends downloading and installing the product software from the HP Website at www.hp.com.
Method one: Install the product software from the CD
1.
If the product software CD is still in the computer CD drive, remove it and re-insert it in the CD drive.
2.
If the software installation does not start automatically, follow the steps below.
1.
2.
In the Open: box, type D:\setup.exe, where D is the letter of the CD-ROM drive.
Follow the on-screen instructions to complete the software installation.
Method two: Download the software from hp.com
1.
Go to www.hp.com and click Software and driver downloads.
2.
Type the model number of your product in the Search box.
3.
Select the operating system of the computer to which the device is connected.
4.
Click the downloaded software to start the software installer.
5.
Follow the on-screen instructions to install the software.
Step four: Use the MSCONFIG utility to enable the Startup software
1.
2.
In the Open: box, type MSCONFIG and then click OK to start the MSCONFIG utility.
3.
On the General tab, select Normal Startup to automatically enable all features the next time the computer is started. In Windows XP, click the Services tab and select Enable All.
4.
5.
Click Restart to apply the changes to the computer.
Jan 20, 2015 | HP Computers & Internet
How to uninstall deepfreeze if forgotten password?
What we are going to do is to load a new instance of Deep Freeze login program and we'll change it in such a way that it will accept any password as a valid one.
Let the Play Begin
The first thing to do is to find some data that we are going to use later to load our login program instance. For this, load the Process Explorer. Once it is loaded, we can see a list of all the processes our system is running, among them is the login program called FrzState.exe or FrzState2k.exe. You may expand the tree if required to find this program. Right click over the program's name and select "Properties". A new window will be opened with the process properties.
Under the Image tab, note the property named "Command Line". Note down the value of "Command Line" including the three numbers at the end of the property for future use in this tutorial.
Run Ollydbg.
Quote Note: Make sure that OllyScript is properly installed. Make sure that the menu "Plugins" and submenu "OllyScript" is available. If this menu doesn't appear in the program, that means the plugin is not installed properly. To install it, go to the menu "Options" and select "Appearance". In the "Plugin path" box write the address where you copied OllyScript files, press OK and restart the program.
On the 'File' menu select 'Open' and look for the login program file (remember that Process Explorer told you where it was). In the 'Arguments' box write the three numbers you've written down. Click 'Open'. If a warning message box shows up press 'OK'. If a message box is encountered with the content "Do you want to continue the code analysis?" - press 'No'.
We have successfully loaded the program. However the problem we face here is that it is protected with Aspack 2.12 due to which we cannot see the real code. To solve this, we are going to use OllyScript and the ASPack 2.12 OEP finder script. Go to the "Plugins' menu, and then to the "OllyScript" submenu and select "Run Script".
Look for the script and open it. The script will find the OEP (original entry point). If any window shows up dismiss it.
Quote Note: We are now on the OEP. If you are an experienced user you can dump the program using OllyDump to analyze the code with a disassembler.
Right click over the code and a context menu will appear, select 'Go to' and then 'Expression' (or use the shortcut Ctrl+G).
In the text box enter the following value according to the Deep Freeze version you have installed and press OK.
VERSION/VALUE
4.20.020.0598 / 40368D
4.20.120.0598 / 40368D
4.20.121.0613 / 4034F5
5.20.220.1125 / 4037E9
5.30.120.1181 / 4037E9
The program will jump to the line of code.
This is the line from where the password verification procedure is called. Let's set a breakpoint here. To do that right click over the line and in the context menu select 'Breakpoint' and then 'Toggle' (or press F2).
We are almost done! Now let's run this new Deep Freeze login program instance. To do that press F9. If everything went right now you should see two Deep Freeze icons on the system tray next to the clock. If Deep Freeze was configured to hide it , instead of two icons you'll see an empty icon.
Quote Note: If the icon doesn't show up is possible that you haven't written the argument three numbers correctly or that you haven't opened the right file.
Now activate the login program by double clicking over the icon while you keep the shift key pressed. If there are two icons, is important that you click over the new icon and not over the old one. The login window will appear asking for the password. Write anything in the password box and press ENTER. The breakpoing we set earlier in Ollydbg will activate and the login program will freeze.
Quote Note: If the breakpoint doesn't activate is possible that you've chosen the wrong icon. Try with the other one.
On Ollydbg press F8 to step over the function call. On the registers window (to the right of the code) you'll see that EAX register has the value 00000000. That means the password is incorrect, let's change that. Double click over the value of EAX to open the modification window. In the 'Hexadecimal' text box write 1 and press OK.
Now press F9 to continue. If everything went right the Deep Freeze configuration dialog will show up.
Sep 04, 2011 | Microsoft Computers & Internet
I am using my headphone but there is no sound at all. i tried checking the master volume in the control panel and its not on mute.
If your Master volume is mute or showing disable its mean your sound card driver is not installed properly. Please install your sound card driver properly. to intall your sound card driver properly please follow these steps
1. keep your system driver's CD in your cd rom
2. on desktop write click on my computer and select the last option of "Properties"
3. a new window will appear select the 3rd tab HARDWARE
4. and now select the first tab DEVICE MANAGER
5. now a new window will appeared on your screen in this screen you can see a mark on the sound driver cross X mark or question yellow mark ? its mean you have any problem in your sound card driver
6. now right click on mark and select update driver
7. select your cd rom and click on next
after installing finish button will appear click on that and restart your PC your sound is enable now.
Jul 16, 2011 | Computers & Internet
Want to print photos from computer to blank cd but can't find how to do it! It's disappeared! Can't even back up my files any more either!
If your programme is not working properly than try to Install neroOEM 6.6.0.8..."Nero Express" and try this procedure From the Nero StartSmart
Select Data Icon> Select Make Data CD> Select +Add> Select the Picture/Pictures "You can select multiples by click and drag system">Add/Finish after selecting the desire picture.> Next> There you you'll see a dialog box appearing: In the dialog box change it according to your desire format/option. 1."Current recorder" choose the CD-R/RW drive.(if you have two drive) in which drive you want to write your picture 2.Disc name "type your desire name" 3.Writing Speed "you can choose anyone from the option" 4.Number of copies: "how many copy of disc you want to write it depend on you"
5. Allow files to be added later 6.Verify data on disc after burning This two it depend on you whether you want to select or not? 7.Burn
Good Luck Thanks
Aug 29, 2010 | Dell Dimension 2400 PC Desktop
Lost CD-KEY for cyberlink powerDVD
hi,
Following is what , i gathered information from cyberlink source
What can I do if I lost my activation key?
Before contacting customer support, try to locate the activation key through the following steps:
If you have registered your products: If you have registered the software, you can log in CyberLink Members Zone and select Manage My Products in the left menu, and then click Manage CD-Keys tab. You will see all the keys you have registered before.
If you haven't registered the products: Retail or boxed versions: If you have a retail or boxed version, the CD sleeve/case should have an activation key sticker attached to it.
Online/Download version: If you have the online/download version, you can check your email inbox for your order confirmation e-mail. It provides you with the product key.
Bundled version: If you got your software free as a bundled version, the CD sleeve/case should have a sticker attached to it. If not, please contact the hardware supplier to get a new key.
If you still have no luck locating the activation key, you will have to register as a CyberLink Member and submit a technical support form to ask for a new key. You will need to attach a digital or scanned image (in .jpg format) of your installation disc as the proof of ownership of the original software copy.
Note: If you are reading this prior to having lost your key, then we strongly recommend that you register your software as this will keep your activation key safe and available if you ever need it. You can always find Online Registration shortcut in the CyberLink program folder of Windows Start menu
Sep 29, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
How do I reset the ink levels?
Well, theres the problem. Most printers can remember up to three cartridges. That includes color & black. The best way to put it is that each cartridge has a"funger print" that the printer can read, and estimated ink levels can be gaged. There is a way to "reset" the cartridges, but i do not have the document on me. Please email steve@nicesites.org and I'll send it today. I'm not saying it will work 100%, as the reset method is geared for the 56/57/58, but who knows right?
Jun 19, 2007 | HP Photosmart C5180 All-In-One InkJet...
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Computers & Internet Logo
844 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
