Question about Refrigerators
Samsung sr-45 ema refrigerator
The freezer is working properly.However, the refrigerator is not cooling, even though the setting is at the coolest.
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
22yooper
  • 828 Answers
SOURCE: my refrigerator does not cool properly
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Posted on May 03, 2008
sandy82
  • 10 Answers
SOURCE: samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
Posted on Jun 08, 2008
Frig keeps freezing even though it is turned down completely
First check that all the cooling tubes are open between the freezer to refrigerator. If one plugs up, then all the cold is focused on one spot in the refrigerator. If that isn't the problem, then replace the refrigerator thermostat.
Jan 18, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
Freezer is cold. Refrigerator side is too warm even on the coolest settings. What do you suggest I do?
freezer is cold. Refrigerator side is too warm even on the coolest settings. What do you suggest I do?
Nov 25, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
Not cool enough
can you cofirm what your model number is,this will be on a tag inside the fridge behind the salad box or behind the bottom draw in your freezer.
Aug 02, 2009 | Refrigerators
It doesn't cool properly
it the freezer froze up?if so its a defrost proublem
May 04, 2009 | Frigidaire PLRU1777DS Stainless Steel...
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
243 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
