Question about Sony RM-U301 Remote Control
Open Sony RM-U301 Remote Control
I'mwould like open the Sony RM-U301 Remote Control, but i'm affreid to brocken the plastik. What i have to take care for? How can i open it?
4 Suggested Answers
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
  • 4348 Answers
SOURCE: How do you set the TV code for the Sony RM-U301
Go to Sony and download a manual for that remote.
Posted on Oct 06, 2010
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
Need instruction manual for sony rm 841 remote control
How can i tune chanells. How can i open the menu for tuning with RM-841
Nov 07, 2012 | Sony Original Tv Vcr Remote Control Rm-841...
Sony internet tv remote stuck
open the remote control and clean the keypads from dirty, corrosion, oxide, and bad contacts, with c. cleaner very well. with carefully.
2) replace a new battery with the same type:alkaline
3) clean the contacts batteries with c. cleaner
4) try again.
5) if the problem persist you have 2 options go to repair shop TV for fix it, or REPLACE IT.
God bless you
Oct 12, 2012 | Sony RM-VL1000 LCD Remote Control
Open remote control sony RM-GA011 for cleaning
how can i open remote control RM-GA011 SONY REMOTE
Oct 01, 2012 | Sony Televison & Video
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
Dear sir, I have a Original Sony Remote Control and the model number is "SONY RM-892". I would like to know how can i open the remote control and to clean up the dirt inside the remote...
Most of the remotes can be opened and cleaned but with care. These remote boxes are self fitting plastics locks and so you need to use a thin blunt knife to wedge open the sides, like removing the car tyre from the rim.
once open you can use a remote control repair kit to clean or form the carbon contact points.
please find tips from the link below:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Apr 11, 2011 | Televison & Video
How do I remove the back of the remote control for a Sony TV? The model number is RM-ED002. I have located two small screws in the battery compartment but removing them doesn't seem to be enough to do the...
The two screws inside the battery compartment would not really hold the case together. Try using two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous.
Aug 22, 2010 | Sony RM-Y132 Remote Control
How can i open my sony rm-ed009 remote control
Feb 11, 2010 | Sony Televison & Video
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
