Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 All-IN-One Inkjet doesn't print
I go through the process of printing and select print and nothing happens. I have checked all cords to make sure they are plugged in, but I don' t even get a message. I have tried rebooting and that doesn't work. Please help with possibilities of what could be the problem and the solutions to those problems.
  • Anonymous Oct 06, 2008
    **** wont print
    Novelist:
    Scholar:
  • 111 Answers
First of all, have you ever been able to successfully print using this printer? If so, my first question would be, what has changed recently on the computer and/or printer that might have contributed to this problem? If you connected another device to the computer recently, it may somehow be interfering with your printer, either because of the physical hardware connection or because of the new device's drivers.
If you have never been able to print using this printer on this computer, the first thing I'd look for is what you looked for...connection problems. If everything is plugged in correctly, another issue might be a bad cord. Assuming the printer is powering up ok, you can rule out a bad power cord. If you are using a USB connector to attach the printer to the computer, check and see if the cord is damaged. It's very common to roll over a cord with your chair, damaging it. Even if it doesn't appear damaged, see if a replacement cord will work.
You could be having a problem with your drivers. You can try to uninstall and reinstall your printer on the computer. This will require the original driver disk that came with the printer. To uninstall the printer, you can follow the steps on this HP.com website:
Uninstalling Software in Windows
Of course, I'm assuming you are using Windows and probably Windows XP, since that's the most common choice, but I could be incorrect.
You can get all the uninstall and reinstall information on the following web page:
Setup and Install
Have you tried printing a test page? If not, see Step 2 of the instructions on the following page:
Wrong Colors
Printing a test page is a good way to see if the issue is with the printer or the computer/application. You might also want to try to print different documents created with different applications (Word, Excel, PowerPoint) to see if they all don't print or only docs from one application don't print.
Please reply with your results after you've given these troubleshooting steps a try. Good luck.
Posted on Oct 03, 2008
HP officejet 5610 All in one printer cannot print or work because power button,Alert button,copy,fax,scan button all were blinking on and off with message on screen Error:0xd05d010d please help, also reset...
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
How to print a page from a website
Please follow the steps to Print a web page using the Internet Explorer or Mozilla web browser.
>Please click on File, Print or press Ctrl+P key and then select the Printer( HP Officejet 5610), select the page range and click OK to print the web page contents.
>You can also preview the web page you're trying to print and then print it (File-->Print Preview).
Good Luck!!!
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Turned printer off during print job. Nothing will print
Try pressing the Power button for 15 seconds to clear the cache. If that doesn´t work, unplug it from the wall and wait about two minutes before plugging again,
Apr 12, 2010 | HP Officejet 5610 All-In-One InkJet...
HP 5610 Error 0xd0620230
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab88
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant print off compute
Hi Grubeman,
The issue seems to be with the printer drivers. To confirm whether the issue is with the printer drivers or with the application, try to print from all the other applications and check for the result.
I have two solutions for your issue.
1. Set "print directly to the printer" option
2. Alternate drivers.
To set the Print directly to the printer option, do the following steps.
1. Open the printer folder
2. Right click on the printer icon and select properties.
3. Click on the Advance tab and select "print directly to the printer" option.
4. Click apply and ok.
5. Nothing else, just try printing dear!!
The second solution, I will post, once I found that the above steps does not resolve your query...
BYE.....
Feb 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Sep 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer not printing properly
Does it happen while printing from all the applications or from only any particular appication or from e-mail/web printing ?
Click Start (Windows Icon) - Printers Folder
Right click on the printer icon Officejet 5600 series and select properties. Click on the Advanced Tab. Enable the option Print Directly to printer. click Apply and OK. Check for the result.
Thanks
Dec 22, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
