Question about Gateway FPD2185W 21 in. LCD Television
Anyone have part #'s on the capacitors?
From what I've read on the fired-capacitor issue, I'm betting mine's next!
Anyone have the type and size of the caps so I can buy in advance?
A schematic diagram of the monitor would be nice...
H.
  • stinkijeans Sep 21, 2008
    Thanks Robert...
    I'm very familiar with electronics... I used to tinker with communications stuff all the time (repair/modify, etc...). I was just wondering if a person could get the caps in advance as I live quite a ways out of town.
    I can't say for sure if my caps are the problem, but sounds like a person should replace them anyway if you're going to crack the case open. I found numerous bad caps in radio equipment. You'd be surprised how many times I've seen a .02 part completely kill a device.
    From what I've read on this monitor, it sounds like I just got a 'shot over the bow'. I'm betting mine is going to fail soon, and probably at the most inconvenient time :).
    I think the only reason it hasn't failed earlier is because I shut mine off regularly.
    This is my first LCD I ever purchased and it's been absolutely flawless. My blind-arse can actually see things now! I bought it from a warehsoue store (Costco). They were far cheaper (at the time) than other local stores.
    I was afraid to buy an LCD at an online retialer due to the DPP (dead pixel policy).
    Most of them allow a certain amount of dead pixels before they'll RMA, etc...
    My thoughts are... I'm spending HOW MUCH money on a monitor? Every single pixel should work perfectly thanks! I wanted a local place to return it to if I found dead pixles.
    So far Ive never had none. The monitor has been excelelnt.
    H.
  • stinkijeans Sep 26, 2008
    Well, my monitor went out twice again... so I decided to pop the case open and have a go at those capacitors.
    BE CAREFUL when poppping the case open and unplugging the connectors!
    Everything is flimsy and can break easy. TAKE YOUR TIME, and be very gentle.
    I keep electronic screwdrivers, tweezers and the like for projects like this. The conenctors were a b*tch to get out with my fat-fingers!!
    Once I got inside, I found the capacitors were NOT bulged out the top, leaking, or leaning; however I noticed some of the bottoms on teh cas were sticking out further htan others.
    Hard to say if they are bad, but it won't hurt to replace them since I'm already knee-deep into it.
    Ok, now time to find the replacement parts:
    The new capacitors were a bit of work to find. My local Radio Shack and their online store didn't have some of them, and the ones they did wasn't rated the same.
    The OEM capacitors are rated 105* (1000 hrs). There were a Samxon brand. According to some web sites, these caps are a general purpose and lower-quality cap.
    The Radio Shack ones are 85*. They would probably work, but who knows for how long.
    I figure the OEM caps are already made by the lowest bidder, so I better not take the chance and make it worse! Besides, Rat Shack didn't even have all of them.
    Here is a list of the caps I found in my monitor (other monitors may be different and you should check yours BEFORE you order them as Robert suggested above)
    * ALL OF THESE ARE RADIAL ELECTROLYTIC (aluminum can type), 105 deg. *
    QTY. (1) 10 uf, 50V
    QTY. (1) 47 uf, 25V
    QTY. (2) 68 uf, 450V
    QTY. (2) 220 uf, 25V
    QTY. (8) 470 uf, 25V
    I found all of the parts at Allied Electronics:https://www.alliedelec.com/
    Total parts was less than $8.
    Allied part #'s:
    10uf: 613-0743
    47uf: 613-0783
    68uf: 613-0312
    220uf: 613-0766
    470uf: 613-0190
    According to their specs, they are good for 2000 hours.
    Digikey also had them:http://www.digikey.com
    Their prices were comparable, but I couldn't get all of the same manufacturer (not that it really matters, but I'm picky like that :) )
    I'll post my results soon as I get the new parts in next week.
    H.
I use this monitor on my desktop system. A great monitor until it died with this same issue. I almost went out and bought a new one, but thought first I'd search Google to see if anyone else has experienced this. That is when I found this posting.
After opening the case and getting the printed circuit board out, I saw that the eight 470 mfd capacitors had slight bulges on the top. I went to Radio Shack. Bought 8 new cap for $1.19 each and a soldering iron and solder.
I'm not an experienced solder(er) so it took me about two hours to remove the old caps and replace the new ones and put the monitor back together.
VOILA!!! It works perfectly!
Thanks to all of you who took the time to post this.
Posted on Oct 13, 2008
    Problem Solver:
  • 5 Answers
I have order several parts I have Replaced my caps and still no luck i ordered about 18 caps and regulators as soon as i get them replaced i will be posting a how to online for everyone so they can see what all goes bad besides the caps there is more a lot more to it than caps! some of you may be able to replace just the caps and get lucky but sooner or later the regulators will go bad as well.
Email me if you have any questions
support@hometowncr.com
Posted on Apr 21, 2009
    Brigadier General:
  • 5,158 Answers
If it's bad caps you likely won't even need a schematic to locate them.... visually inspecting them doesn't always work. you need to feel the tops of them. if they feel rounded on the tops or swelled up.... replace them. be sure to orient them the same way as the old... they have a positive and negative so be aware of the stripe on the side. the uf number has to be exact but a replacement with a higher voltage rating is exceptable.
I fixed a benq monitor with the same issue so good luck and ask if i've missed something you need to know. oh and the parts can be bought at radio shack (in the states) or grab a phone book and look up electronic parts.
Robert
Posted on Sep 21, 2008
  • Roberta Smith
    Roberta Smith Sep 21, 2008
    well reverse problem again... yeah you would need the schematic... only thing is then you need to take it apart to know what caps need replacement. so like it or not you are going to have to crack the case and make a list of what you need. yeah the dead pixel thing always bugged me, my feeling was that i paid a fortune (well my wallet screamed when i took the money out) so either it's working as it should or not. here's an issue for you and i've seen it... tiny bugs got in behind the lcd screen on a monitor and were moving around....... ohhhhhhhhhh what a bugga that would be.
    Robert
Need advice on capacitor purchase for pentair spa pump
There are so many models of what may appear like the same motor, but the internals may vary????
If you can take off the cover & look at the capacitor itself, that is your best bet. You need to at least be at the equivalent of the same range of MFD!!!! Example 72 - 93 MFD!
You can go slightly higher, but not by much!
If you can't read what you currently have, then contact Pentair directly. They may be able to assist you with the right information.
Here is a link for your assistance...
Contact Pool Expert PENTAIR
Apr 27, 2015 | Pentair 1.0 Hp Whisperflo Pump
Was smoking. Took back off and found a capacitor where it was coming from. Can I remove it without having to replace it?
No Walter
That capacitor is there for a reason.
It MUST be replaced with an electrically identical one but before doing that, I'd certainly want to know the reason why the smoke was let out of the original.
-Steve
Apr 17, 2015 | Televison & Video
I have a 5 yo 52" Samsung lcd.From a cold start it cycles on then off about 6 times before a picture comes on.I replaced capicitors and no difference. Whats next?
Most of the time only secondary large electrolytic capacitors are being renewed althoug small E. capacitors in a primary circuit of an smps (around the switching driver IC) can also cause this kind of issue. Although you say you replaced them i still believen its a bad capacitor.
Jan 29, 2015 | Samsung LN52A630 52-Inch 1080p 120 Hz LCD...
What SIZE light bulb do i need to I replace in my GDM 12 coke fridge?
hi,this is how i fixed mine ,i took off the light tube and the little silvercup next to the light (capacitor) took them with me to home depot to match the numbers and sizes it took me about two minutes to find them, the capacitors come in silver and plastic housing and they come in pairs but not expensive,good luck.
Mar 05, 2014 | True GDM-12 Refrigerator Commercial
Size of Capacitor
capacitors are rated in microfarads . they have a number followed by a symbol that looks like a scribble. if i wanted to replace one, i would take it to the nearest electronics store for identification. or a delco distributor, where i could expect a price on a new unit
Apr 29, 2013 | Ac Delco Vehicle Parts & Accessories
Ln40b650t1fxza won't turn on, no power
The power supply capacitors would be my first guess. Open up the set and check the power supply capacitors. If you see any with bulging tops, that is most likely your problem. If the caps are bad, they can be bought for about $5-$10.
Jan 26, 2013 | Samsung Ln40b650 40 1080p Lc ln40b650 /...
My LCD TV Series 530 keeps on blinking and would not turn on. why does it keep doing that?
I've experienced similar issues with a 42" Samsung LCD TV. From what I've read online, I believe it could be a problem in the circuitry of the power supply. Apparently, Samsung used under rated capacitors in the power supply and the result is a turn on delay or blinking on and off. If this is the case, then the capacitors would need to be replaced to fix the issue.
Aug 07, 2011 | Samsung Televison & Video
Toshiba 50h13 picture shakes/ horizontal issue but OSD is good
check out any other capacitor blown or bulged up near to the ic chip .
Nov 26, 2008 | Toshiba 50H81 50" Rear Projection...
I cannot find the internal backup battery.
I ran into the same issue with my Onkyo 787 receiver that the internal settings would get reset after a short power off. Getting all settings entered again (preferences, speaker distances, volumes, stations, etc.) is a real pain. Good news is that Onkyo DOES have a battery (actually a capacitor) to store the settings and that capacitor can go bad. Another good news is that replacement is quite easy.
The settings are preserved by a 5.5V 0.1F capacitor. Digikey sells it for around $1.50, you may choose a higher capacitance, as 0.3F if you're replacing it. I didn't want to wait for the part, so I decided to replace with something I had around from an old power supply. I used 10V 1000uF capacitor as a replacement and it works fine. Yes, it is 100x less in capacitance, but preserving setting for a short time is better than not preserving them at all. Settings survived a couple of days disconnect and I haven't tried leaving the receiver off for any longer yet.
Here's how you can find it: it's on the main horizontal board, on the same side where the volume control is. It's small, looks like a watch battery turned on the edge. Mine was in a blue shrink wrap. I cut off the leads next to the battery and left the wires sticking out of the PCB. There's plenty of room to put any capacitor.
Pixonian
Aug 13, 2007 | Onkyo TX-DS787 Receiver
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
380 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
