Question about Apple iPod classic MP3 Player
Ipod When I turn it on My ipod classic shows the image of a battery an its stuck there. Once in a while it shows the apple icon or an ipod that is is not feeling well. I tried to reset, restart and nothing works, My warranty run out.
  • tortellini76 Nov 05, 2008
    my ipod classic 160gb is stuck either on the battery symbol or the apple logo. Did anyone ever solve this problem. It's out of warranty so I will have to fix it myself. Help Please!!!
  • Apple Master
  • 2,794 Answers
Take you ipod to your nearest Apple Store or Best Buy to find out what the problem is.  It could be the hard drive or the battery.  When the sick image display is on the screen, it has to be taken in for service.
Posted on Sep 21, 2008
Shuffle not working
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked.
When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Oct 15, 2012 | Apple iPod classic 6th Generation Digital...
IPOD Classic 80G apple icon then red x icon or restore in itunes
I know you tried to fix it, but trying multiple times may work.
The message "go to www.apple.com/support/ipod" usually is preceded by, or followed by, the Apple logo or the sad face icon. It directs you to the Apple support site because either the iPod software is corrupted or their is a hardware problem. You should try to reset the iPod (try several times). If that doesn't right the iPod, then try to restore it (which will erase the entire iPod and reload the software.
Follow the links above and see if that gets your iPod working. You might want to see if you can update the iPod/iTunes software or try this troubleshooting guide. If it is really a hardware problem then your iPod needs to be taken in for service.
Mar 29, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod 120gb ipod classic does nothing but show apple logo and never disapears
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menue. Then connedct the iPod to your computer and update or restore the iPod.
Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod .
As always make backups of your music files, because the restore procedure will eliminate them.
Good Luck,
I hope this helps
Nov 02, 2009 | Apple iPod classic MP3 Player
Battery icon won't show when charging...
Have you already reset the iPod? If not I would try that first. It may be that your battery is shot though. It's not a relatively expensive repair though.
To reset the iPod Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If that does not start the iPod to charging you can go to (www.rapidrepair.com) and view free repair guides that show you how to replace the battery as well as how much it will cost to replace. Good luck. Hopefully the reset resolves your issue and you will not need a new battery. Let me know how it turns out
May 27, 2009 | Apple iPod classic MP3 Player
Ipod only works wih a power source
Well there is a remote chance it's a battery issue, but most likely you have a broken logic board. If you're not covered under the warranty you can try to open it and make sure the battery is connected properly. There are iPod repair guide websites, that show how to open the iPod classic and replace components.
May 10, 2009 | Apple iPod classic MP3 Player
Plugin to wall icon after restore to factory setting
you need a different wallcharger, try an original apple USB wallcharger, you will only need it once. it will not complete the restore on the usb port of a pc. there is a free guide online that shows you how to open an ipod classic if it is actually broken.
Apr 05, 2009 | Apple iPod classic MP3 Player
Apple ipod classic 160 gb
connect ipod to pc..........let itunes (make sure it the latest version) come up....your ipod icon shows up update (let itunes check if your firmware is up-to-date) if so this should do the trick.
Jul 13, 2008 | Apple iPod classic MP3 Player
Ipod wont show up on itunes
try these websites. it can be a frustrating problem.
http://www.apple.com/support/ipod/five_rs/classic/
http://docs.info.apple.com/article.html?artnum=93716
make sure you follow all of the steps
good luck
Dec 14, 2007 | Apple iPod nano
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod classic MP3 Player Logo
71 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
